Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Leak under sink need help
Thread Tools Display Modes
Old 04-29-2014, 02:22 AM   #1
Fightingfungus
Liked 1 Times on 1 Posts
Default Leak under sink need help
I was attempting to changed kitchen faucet. The bolts on the water lines were so tight that I believe I may have damaged the water valve (were the water shuts off under sink) I have the water valve off but I still have a leak. Any one have any idea how I screwed up and how I could fix it. Will probably call a plumber.
Fightingfungus is offline
Old 04-29-2014, 02:40 AM   #2
havasu
Administrator
havasu's Avatar
Liked 1109 Times on 901 Posts
Likes Given: 327
Without a picture, anything would just be a guess.
1) How about tightening the packing nut, which is located behind the handle to the valve?
2) With the aid of a bucket, have you tried opening and closing the valve numerous times to see it you can stop the water?
havasu is offline
Old 04-29-2014, 03:47 AM   #3
journeyman
the professional
journeyman's Avatar
Liked 142 Times on 111 Posts
Likes Given: 142
Turn water off to house and install new quarter turn valve. They leak because they are never used and calcium builds up. Once seal is broken they leak.
journeyman is offline
Zanne Likes This
Old 04-29-2014, 05:04 AM   #4
Fightingfungus
I tried that. The sad thing is I could not even remove the old faucet. Everything is wound up very tight, I could not even remove the bolt with a basin wrench. The bolt is huge and basin wrench hardly fits over. I tried w40 and still can't get it.
Very frustrating
Old 04-29-2014, 11:48 PM   #5
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
Plumbing repairs can definitely be very frustrating.
It is rather common for the supply valves under a sink not to hold and leak slightly. The best fix for that is usually to replace them.
A corroded faucet can be a real pain to remove. Sometimes a Dremel tool is the easiest way to get a nut off.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
SHR Likes This
Old 04-30-2014, 05:04 AM   #6
Fightingfungus
A plumber came out today and took care of the job. He changed 2 water valves, 2 faucet connectors and installed a faucet for me that I purchased. The job took him 1.5 hours and he charged me $200.
My dad said he ripped me off and it should have been(120-140 tops). I thought the price was fair being he came out the same day I called him.
phishfood Likes This
Old 04-30-2014, 11:14 AM   #7
johnjh2o
johnjh2o's Avatar
Liked 717 Times on 544 Posts
Likes Given: 610
All Dads think that prices are to high. I put myself in the same category. We are living in a older time when prices were lower.
John
johnjh2o is offline
Old 04-30-2014, 03:41 PM   #8
CT18
Liked 47 Times on 38 Posts
Most rates are around 150 an hour depending on where you live. I remember a few times explaining to customers that you take your car TO a mechanic. When you are sick you go TO the doctors office. I am sure if you brought your plumbing to them it would be less. Service companies have fuel and insurance charges for vehicles that factor in with all other expenses. They also have to stock parts on the vans.
CT18 is offline
Old 04-30-2014, 09:42 PM   #9
SHR
Liked 276 Times on 209 Posts
Likes Given: 766
Price was very fair considering the amount of skilled work done. Thank you for understanding the fairness of the price. When someone expresses their opinon that the charge "should have been..." I tell them, "great, go ahead and do it." They never take me up on it.
SHR is offline
Old 04-30-2014, 09:55 PM   #10
havasu
Administrator
havasu's Avatar
Likes Given: 327
I myself am pretty frugal, and will do pretty much anything to save a buck. Looking at the amount of work the professional did for you, I also don't feel he charged you that much.
havasu is offline
SHR Likes This
Is this a splash leak or pipe leak? Fightingfungus General Plumbing Help 1 11-02-2013 01:40 AM
Need help understanding sink drain leak dperry9 General Plumbing Help 20 05-01-2013 02:35 PM
Sue manufacturer for leak after 3 months? sink shut off valve soggywalls General Plumbing Help 6 03-12-2013 12:49 PM
Leak under kitchen sink flyerphann General Plumbing Help 13 05-29-2011 04:42 PM
Is my leak under sink or behind wall? SP284 General Plumbing Help 7 10-08-2010 11:19 PM
Newest Threads
