Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Purpose of this plug?
Thread Tools Display Modes
Old 04-19-2014, 11:25 PM   #1
MacPlumber2944
Likes Given: 1
Default Purpose of this plug?
This could be a pressure relief valve, I'm not sure. Anyway, it's a Moen, and started spraying water outward.
MacPlumber2944 is offline
Old 04-20-2014, 01:41 PM   #2
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
I don't recognize what it's even used for. Maybe some more details and photos from other angles.
Caduceus is offline
Old 04-20-2014, 05:00 PM   #3
Matt30
Liked 734 Times on 557 Posts
Likes Given: 199
Anti siphon?
Matt30 is offline
Old 04-20-2014, 05:08 PM   #4
MacPlumber2944
Likes Given: 1
thanks. the plumber took away the old parts, so no more pics avail. after his installation of a new Koehler unit, there was no flow, so he took off something and found a piece of mangled O-Ring that had been impeding flow. Giving rise to my suspicion that had been the problem all along; blocked line-subsequent spray from this "plug", causing water to accumulate on the countertop and into the cabinet. I would've never figured this out on my own, glad I called a professional.
Old 04-20-2014, 08:01 PM   #5
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Some of moen old kitchen faucets like the pure touch or one touch had a vaccum breaker. That looks like the vacuum breaker in the old one touch.
IFIXH20 is offline
MacPlumber2944 Likes This
Old 04-21-2014, 12:38 AM   #6
MacPlumber2944
Likes Given: 1
"Old" was used by someone at the plumbing supply, which greatly surprised me. House built in '97. I'd never have considered anything old yet. What does a vacuum breaker do, exactly?
Old 04-21-2014, 01:22 AM   #7
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
It protects against possibly contaminated water being sucked back into the water supply piping, in the event that a water main somewhere is cut or broken. If a siphon is created on the side of the vacuum breaker that is normally pressurized, it will open and allow air into the piping, and block water from the output piping from flowing backwards.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
People Like This
Old 04-21-2014, 03:46 PM   #8
MacPlumber2944
Likes Given: 1
Thanks very much.
Help I dentifying the purpose of these pipes? Fusion916 General Plumbing Help 2 08-04-2013 01:26 AM
Purpose of cold water tank in basement? threehappypenguins Water Heaters and Softeners 5 01-02-2013 11:55 PM
Where To Find a 1/2" Plug - LHT ? abrogard General Plumbing Help 7 01-04-2012 08:42 PM
leaking cleanout plug-help! shainchu1 Drain and Sewer Cleaning 3 09-13-2011 01:21 PM
Newest Threads
