Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Need some drain help
Thread Tools Display Modes
Old 04-17-2014, 01:17 AM   #1
Otahyoni
Established Member
Otahyoni's Avatar
Liked 13 Times on 11 Posts
Likes Given: 1
Default Need some drain help
I'm redoing my bathroom and need some advice on how to redo the drains.
Here's a drawing of what I have now:
I'd like to keep the toilet and sink where they are, but the tub will be replaced by a shower so I'll need to redo that part. The current toilet drain is cast iron with the sink and tub being galvanized.
I would like to cut the cast iron at the verticle just before the clean out and replace everything above with PVC. What I'm not sure about is the routing and what order to plumb things in.
Can you guys help set me straight?
~The Amish Wolfman
I am known by many names:
Otahyoni, Otah, Utah, Chris, Steve, Fred, The Amish Wolfman, and Mark's Little Buddy... :D
Otahyoni is offline
Old 04-17-2014, 11:28 PM   #2
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
Here are a couple of drawings.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 04-17-2014, 11:34 PM   #3
phishfood
Administrator
Likes Given: 1739
This is a detail of what the current vent should look like when you are done.
Old 04-18-2014, 12:10 AM   #4
Otahyoni
Established Member
Otahyoni's Avatar
Likes Given: 1
Crap. This means I'm going to have to make one wall thicker.
Does any horizontal section of vent have to be sloped towards a drain?
Does the shower have to be vented?
Another thing, currently the sink drain drops down through the floor. If i had to move it into a wall with a vent it would be right over the center of a doubled joist. How would I get around this?
Edit: forgot a word...
~The Amish Wolfman
Otahyoni is offline
Old 04-18-2014, 01:17 AM   #5
Otahyoni
Established Member
Otahyoni's Avatar
Likes Given: 1
Heres some better pictures of what my current setup is:
~The Amish Wolfman
Otahyoni is offline
Old 04-18-2014, 02:02 AM   #6
Otahyoni
Established Member
Otahyoni's Avatar
Likes Given: 1
Ok... I've been throwing ideas around and I think I've got something that will work...
This is views from a couple angles, but my rough idea.
The way I drew it, the sink and shower go into the top of a 3x3x2 sanitary T. Only the sinks vent goes through the roof, the showers goes to the sink vent in the attic. The shower's drain comes between the joists and drops down from above the sink's drain via a 1.5x1.5x2 sanitary T.
Does this sound ok? I'm getting a new roof, so nows the time to move the vent if I need to...
~The Amish Wolfman
Otahyoni is offline
Old 04-18-2014, 09:35 PM   #7
phishfood
Administrator
Likes Given: 1739
I don't know Indiana code, but in my area it is to code (and works very well) to vent the entire bathroom through the sink's vent. However, since you have the height to work with, and there is already a vent there to work with, it won't hurt to vent the shower as well. The way you have the shower drain/vent arrangement drawn middle right of your drawing is correct, make sure you do it just that way. The sink vent needs to be there, even if it isn't there at present.
Old 04-19-2014, 01:01 AM   #8
Otahyoni
Established Member
Otahyoni's Avatar
Likes Given: 1
Thanks for getting me set, phish.
~The Amish Wolfman
Otahyoni is offline
Old 04-28-2014, 11:52 AM   #9
roliza
Are you doing all this by yourself
roliza is offline
Old 04-28-2014, 12:02 PM   #10
Otahyoni
Established Member
Otahyoni's Avatar
Likes Given: 1
Yes. I have plumbing experience, just not as a trade.
~The Amish Wolfman
Otahyoni is offline
Newest Threads
