Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Water in top too hot
Thread Tools Display Modes
Old 04-10-2014, 01:53 PM   #1
britkath
Liked 2 Times on 1 Posts
Default Water in top too hot
What would you do if you had a 1000 gallon water heater that the water is getting too hot in the top of the heater, and tripping the T&P relief valve?
britkath is offline
Old 04-10-2014, 10:57 PM   #2
SHR
Liked 282 Times on 214 Posts
Likes Given: 776
Gas or electric?
SHR is offline
phishfood Likes This
Old 04-11-2014, 02:01 PM   #3
britkath
Quote:
Originally Posted by SHR View Post
Gas or electric?
Electric water heater
britkath is offline
Old 04-11-2014, 03:20 PM   #4
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
I would wonder why this suddenly started to happened and maybe check for a circulating pump that is non-op or a thermostat issue.
Caduceus is offline
Old 04-11-2014, 03:30 PM   #5
johnjh2o
johnjh2o's Avatar
Liked 723 Times on 547 Posts
Likes Given: 616
Are you sure it's tripping because of temperature and not pressure? Is there a thermo expansion tank on the heater?
John
johnjh2o is offline
Old 04-12-2014, 12:35 AM   #6
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
And a properly sized thermal expansion tank, at that. A 1000 gallon heater is not something that can be served by a standard expansion tank. Or, if the expansion tank is of the proper size, has the bladder failed?
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 04-12-2014, 12:51 PM   #7
Caduceus
Caduceus's Avatar
Likes Given: 230
Good call, guys. I assumed that a 1,000 gallon tank in a commercial setting would have temp and pressure gauges in the proper locations to make thermal expansion and easy issue to rule out of the equation.
Caduceus is offline
Newest Threads
