Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > cost of underground (concrete) water line repair
Thread Tools Display Modes
Old 04-05-2014, 12:53 AM   #1
nj2012
Likes Given: 4
Default cost of underground (concrete) water line repair
I have water leak under the concrete ground in the basement. There is no visible water. But the sound is coming right where the water pipe comes up from the slab. The meter isnt running because it's before the meter.
I called a plumber and was quoted $1800 to jackhammer that area and repair the leak only. (old house, probably better to just replace the whole thing to the city main line). The cost to go all the way out to the city line is $6900.
I have a couple of questions.
Are those pricing reasonable?
He explained to me that he must cut up my concrete driveway to replace the entire pipe.
Might be a dumb question but is that even necessary? can't he just dig a hole in my basement/garage where the pipe is coming up from and dig a hole on the street where the main line is? instead of messing up my entire driveway.
nj2012 is offline
Old 04-05-2014, 01:56 AM   #2
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
There are trenchless options for replacing water mains, but they won't work for every situation. They are expensive, but usually cheaper than removing driveways, expensive landscaping, etc. Not all that many people offer this, as the equipment tends to be expensive, and the learning curve to effectively use the equipment is pretty steep, so you might have to do some searching to find someone qualified to even determine whether trenchless would work in your case.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 04-05-2014, 05:48 AM   #3
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
If it is before the meter, 90% of the time it is owned by the water company and they are responsible for the repair. I would contact them first just to see. I know in Southern California they are all owned by the water companies.
Sent from my iPhone using Plumbing Forum
Chris is offline
Old 04-06-2014, 09:46 PM   #4
nj2012
Likes Given: 4
So here is some information so you guys can evaluate the quote and let me know if it's a fair price.
This is from a reputable plumbing company, good reviews, A+ BBB rating.
They will install new piping from the water box (I will make sure I'm responsible from the water box and not the actual main) the valve inside my house (above ground).
They will use 1" Poly pipe. (Is this better than copper)?
They will do everything including get permit, pour concrete back in the ground.
QUOTE $6200
nj2012 is offline
Old 04-06-2014, 10:01 PM   #5
havasu
Administrator
havasu's Avatar
Liked 1114 Times on 906 Posts
Likes Given: 336
How many feet are they trenching? How much concrete is being jacked out and replaced? Don't let the BBB rating fool you, that company is fixed. Did you get three quotes? If not, please start calling others to give you a good comparison.
havasu is offline
nj2012 Likes This
Old 04-06-2014, 10:07 PM   #6
nj2012
Likes Given: 4
Quote:
about 20 feet of concrete.
They will replace 6feet x 6feet concrete slabs (part of driveway), and then cut out the rest I guess as much as they can to get the pipe in. About 14 feet in length not sure how much width they need to put down the pipe.
I got 4 quotes.
1 = 5000 not including concrete work and I have to get permits.
2 = 3000 not including concrete work and I have to get permits.
3 = 6800 including everything
4 = 6200 including everything.
Is 1" poly better than copper. According to the plumber they can put copper if I would like. But he said they chose poly because of sand under the concrete or something like that.
wow about BBB. What about google reviews. they have 124 reviews and 4.6 out of 5 stars.
nj2012 is offline
Old 04-06-2014, 11:44 PM   #7
phishfood
Administrator
Likes Given: 1739
Ask about trench compaction. You don't want the repaired sections of driveway to be sinking and cracking because they just dropped the dirt back into the trench, without compacting it every foot or so.
nj2012 Likes This
Old 04-06-2014, 11:47 PM   #8
nj2012
Likes Given: 4
Quote:
He said the trenchless would need 4 to 5 feet from each end. Which will be half of the driveway. Do you think that's a better option? Also it should be cheaper right?
nj2012 is offline
Old 04-06-2014, 11:49 PM   #9
Chris
Administrator
Chris's Avatar
Likes Given: 67
Price sounds about right for Southern California
Chris is offline
nj2012 Likes This
Old 04-07-2014, 03:55 AM   #10
journeyman
the professional
journeyman's Avatar
Liked 143 Times on 112 Posts
Likes Given: 148
Plastic pipe is trash. Use copper. A 1 inch line is good in case you should add anything in the future. Line only has to be 12 inches deep. Make sure to compact dirt like phishfood said and make sure they re-enforce concrete patch with rebar. Is there anyway to run new line with out digging up driveway? Make sure there is not a way to run line differently
journeyman is offline
possible to find out exactly where water line runs underground? tr888 Plumbing Tools and Equipment 15 06-05-2014 03:58 AM
Cast iron sewer line repair hammermill General Plumbing Help 2 03-21-2014 12:15 AM
Distributed Underground Hot Water piping Joe_Joe General Plumbing Help 2 10-28-2013 04:26 AM
Tankless Water Heater Cost for Homeowners Bodishr Water Heaters and Softeners 4 03-07-2013 10:58 PM
What would you do? Irrigation line repair. TexasTwister General Plumbing Help 6 06-26-2012 03:09 PM
Newest Threads
