Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > toilet valve shut, but still leaks
Thread Tools Display Modes
Old 03-27-2014, 05:10 PM   #1
needstlc
Default toilet valve shut, but still leaks
I know I will eventually need a plumber, but I would like a temporary solution to this problem. I have a toilet that has a leak coming from above the shut off valve. The valve is off, but the water still drips. There is water in the tank that never drains or seems to evaporate. If the leak doesn't empty the tank where is the water coming from? Do I need to drain the tank? If there is still a leak after I drain it should I find a way to keep the flush valve open so the water goes into the toilet? The water leaks outside the toilet, into a small basin.
needstlc is offline
Old 03-27-2014, 06:24 PM   #2
alefromitaly
alefromitaly's Avatar
Liked 258 Times on 211 Posts
I don't know if I have translated right.. I try to answer.. Are you sure that the valve is completely closed?Anyhow, the tank should have a overfull inside the drain valve..when the water enter, and the filler not stops , when water passes the level of overfull pipe, goes into the toilet..After your plumber will change the filler..I'm sorry if I dont understood your question..
alefromitaly is offline
Old 03-28-2014, 12:40 AM   #3
phishfood
Liked 937 Times on 753 Posts
Likes Given: 1672
It sounds as though the supply line is leaking, and the shutoff valve is not holding.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is online now
Old 03-28-2014, 04:28 PM   #4
needstlc
Is this a minor job that I can handle on my own with instruction?
needstlc is offline
Old 03-28-2014, 04:46 PM   #5
havasu
Administrator
havasu's Avatar
Liked 1045 Times on 842 Posts
Likes Given: 284
Very simple. If you can post a picture or two, we will show you exactly how to do it.
havasu is offline
Old 03-28-2014, 04:55 PM   #6
alefromitaly
I agree with havasu..
Old 03-29-2014, 12:05 AM   #7
phishfood
Likes Given: 1672
We can probably talk you through this.
First thing we need to do is make sure of what your problem is.
Shut the valve under the toilet off fully. Flush the toilet, and hold the handle down until all of the water empties. Use a shop vac or a sponge to get most of the rest of it. Then, if the tank slowly starts refilling with water, you know that the shutoff valve isn't holding.
Next, add some food coloring to the tank, and then turn the water back on. Make sure that there is enough food coloring to give a decent tint to the water. Now you will be able to tell for certain if the leak is coming from the tank or the supply line.
Report back, with a few pictures.
Old 03-30-2014, 05:57 PM   #8
needstlc
OK, thanks for the help.
needstlc is offline
Old 04-10-2014, 03:00 PM   #9
needstlc
The valve is still off and the tank almost completely empty. The drip continues, but is next to nothing in comparison to what it had been. I notice that when I raise the float ball, the drip increases, if that is an indicator of anything. I will now wait to see it the tank refills.
needstlc is offline
Old 04-11-2014, 10:29 PM   #10
needstlc
It took about 20 hours for the tank to refill and for the rate of the dripping to reach the point where it was before the tank was drained. I added coloring to the tank, the basin does not contain colored water.
needstlc is offline
Shut off valve bggas400 General Plumbing Help 12 12-14-2012 11:26 PM
Water shooting out from shut off valve clunt22 General Plumbing Help 3 03-13-2012 11:14 PM
Help: Replace Main Shut Off Valve CWC General Plumbing Help 3 04-13-2011 06:30 PM
Washer Shut Off Valve ericakoe General Plumbing Help 4 09-15-2010 07:10 PM
Shut off valve sjc67 General Plumbing Help 5 02-21-2010 01:30 PM
Newest Threads
