Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Building Code > Indirect waste receptor
Thread Tools Display Modes
Old 12-16-2013, 11:24 PM   #1
britkath
Liked 2 Times on 1 Posts
Default Indirect waste receptor
Per IPC, can a floor mounted Janitor's sink function as both a janitor's sink, and an indirect waste receptor?
britkath is offline
Old 12-17-2013, 12:05 AM   #2
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
Chapter 8, Indirect and Special Wastes, does not clearly state whether or not a floor sink can be used as a waste receptor, Chapter 2, Definitions, does not define a waste receptor. The janitor's sinks that I have installed do have a removable strainer or basket, which is one of the stipulations for a waste receptor in Chapter 8.
So, while I am not the code authority in your or any other area, I would say yes, and be prepared to argue with the inspector on that point. I don't see where the sink being used for a janitor's sink has any bearing on whether or not it can serve as a waste receptor.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 12-17-2013, 12:50 PM   #3
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
It also depends on what is being discharged into the janitor's sink (mop sink?)
In my area, the janitor's sink can only receive the indirect discharge of clear liquids such as condensate or clear water overflow and emergency discharges.
Any fixture that could discharge solids or debris that may clog sink's strainer are not allowed to empty into it.
Caduceus is offline
Need help hooking up low voltage to Indirect water heater. JohnDS General Plumbing Help 1 12-02-2013 01:44 AM
Can someone recommend which 50gal indirect water heater to get? JohnDS General Plumbing Help 2 11-28-2013 06:15 PM
New Indirect heater Install Confusion Roger2561 Water Heaters and Softeners 4 02-11-2012 09:35 PM
Two bathrooms, one waste stack d_san Plumbing Building Code 3 07-16-2010 03:32 AM
waste water recovery waschehaus General Plumbing Help 10 06-11-2010 01:38 AM
Newest Threads
