Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Still low pressure after replacing diverter
Thread Tools Display Modes
Old 12-06-2013, 01:51 AM   #1
greedo1028
Default Still low pressure after replacing diverter
Our water pressure was very low today in our shower. We have a three handle faucet fixture from approximately 1982. I did some research and it sounded like the diverter needed to be replaced. When I removed it, the plastic washer was almost completely disintegrated.
I found a replacement at Home Depot (a Danco 9H-3D for a Price Pfister faucet) and installed it, and it looked like everything was fine. Shower water pressure was returned to normal. I noticed that the plastic O-ring from the new diverter had fallen off before I installed it, so I removed the diverter once more and put the O-ring back on. This time, though, the water pressure was back to the weak amount that I had before.
I have not been able to recreate that one instant of good water pressure. I've tried every configuration: new valve, old valve, with and without the O-ring. I've even tried the old valve with the new plastic washer. The water all seems to be going up to the showerhead -- no water is coming out of the tub spigot when the shower is running. However, the amount of water coming out of the shower is nowhere near what comes out of the tub.
Any suggestions? I read that using silicone grease on the washers can help give a better seal -- do they make that much of a difference? I can't figure out why the water pressure would change so abruptly.
greedo1028 is offline
Old 12-15-2013, 12:56 PM   #2
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Remove the diverter stem again. After removing stem look inside of valve body with a flash light, a piece of the old stem bibb washer may lodge inside of valve body. Also remove the shower head to check for blockage.
IFIXH20 is offline
johnjh2o Likes This
Old 12-15-2013, 01:05 PM   #3
johnjh2o
johnjh2o's Avatar
Liked 717 Times on 544 Posts
Likes Given: 610
Quote:
Also try removing the shower head there may be some parts of an old washer lodged in it.
John
johnjh2o is offline
Shower Diverter help aziandude1 Showers and Tubs 13 08-23-2014 12:32 AM
Shower diverter chexny Showers and Tubs 3 10-01-2013 03:51 AM
Help with ID of a very old diverter valve dan5982 Showers and Tubs 0 08-03-2011 09:03 PM
Repurpose a 3 way diverter? kirbyg Showers and Tubs 4 05-29-2011 10:18 PM
What Type of Diverter? nrdo Showers and Tubs 1 01-03-2011 10:56 AM
Newest Threads
