Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > No hot water out of my bathroom tap. Why, oh, why?
Thread Tools Display Modes
Old 11-08-2013, 12:47 AM   #1
susan
Liked 2 Times on 1 Posts
Likes Given: 4
Default No hot water out of my bathroom tap. Why, oh, why?
No hot water whatsoever is coming out of the bathroom tap. This is the only tap in the house that is affected. Because we have relatively hard water, and the flexible line running from the shut off valve under the sink to the faucet has one of those flood safe connectors, I thought it was very likely the line was plugged with sediment. I removed the line, and sure enough, it was plugged. Yea! Jubilation! Problem solved! So I unplugged the fitting and line, even soaked it in a solution of CLR. After I reattached it to the water line, I opened up the valve to determine if water would flow through the line or if the problem might be elsewhere. No issues, water flowed at a steady even rate. A triumph. I was even going to have enough daylight for some garden clean up. I reattached the line to the faucet (it has separate hot/cold handles, but a single spout). Opened up the water line, turned the handle, and.....nada. Despair. Must be in the faucet - so I commenced to take that off of the flexible lines, and ran water through that. Ran it did. For good measure I soaked that in CLR, too. Reassembled the whole thing with very little optimism at this point. Turned the handle. Nothing. Absolute bafflement. Here's a possible clue: when the handle is turned, the pipe in the basement makes a "thunk". This is a well constructed mid century home, and the faucet in question is only a couple years old and of a good quality. Help! My frustration is all consuming.
susan is offline
Old 11-08-2013, 12:59 AM   #2
havasu
Administrator
havasu's Avatar
Liked 1063 Times on 859 Posts
Likes Given: 297
You appear to have deep seated sediment in your faucet. I'd recommend you start taking it apart, starting with the screen aerator, which is usually where the sediment collects. Once it is cleared up, then you need to either consider a filter or repiping, whatever is needed.
havasu is online now
susan Likes This
Old 11-08-2013, 01:00 AM   #3
phishfood
Liked 939 Times on 755 Posts
Likes Given: 1679
How did you run water through the faucet with it unhooked from the supply lines?
Did you remove the hot side cartridge from the faucet and check it for sediment deposits?
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
susan Likes This
Old 11-08-2013, 02:27 AM   #4
susan
Likes Given: 4
I failed mention that I completely cleaned the aerator - cold water flows unimpeded. I maybe wasn't also clear that I removed the entire faucet from the sink, which is why I was able to run water through the threaded pipes at the base. I flipped it over, and with the cold water handle closed and hot open, I poured water through the bottom. It came out of spout without any problem. I don't this the faucet is the issue. I'm not sure what you mean by removing the hot cartridge, though. Could you elaborate? The following link has an image of the faucet I have.
http://www.plumbingwarehouse.com/ame...lton-7024.html
susan is offline
Old 11-08-2013, 02:40 AM   #5
johnjh2o
johnjh2o's Avatar
Liked 701 Times on 533 Posts
Likes Given: 589
Replace the flood safe supply with a standard supply tube.
John
johnjh2o is offline
People Like This
Old 11-08-2013, 03:53 AM   #6
Mr_David
Easily Amused
Mr_David's Avatar
Liked 769 Times on 622 Posts
Likes Given: 535
I agree with john The flood safety supply is probably causing the thunk you hear as it closes off the supply.
a.k.a. Krazedav
Mr_David is offline
susan Likes This
Old 11-08-2013, 10:08 PM   #7
susan
Likes Given: 4
Sucess! I abandoned the flood safety supply, and replaced it with a standard supply. I may no longer be safe from floods (but who really is?), but at least we'll have warm water to wash our hands. Thanks for all your input - heroes all of you. I really appreciate this forum; look for further queries from me regarding confounding plumbing puzzles. I still have two unsolved on the docket, but I'm putting away my wrenches and enjoying the weekend.
susan is offline
People Like This
Old 11-10-2013, 04:02 AM   #8
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
Likes Given: 1
I can't count how many times I went to a house and it was those stupid floodsafe supplies. I hate those things!
camaroderrick73 is offline
No hot water in 1 bathroom and kitchen, but Ok in other places ilya General Plumbing Help 3 09-05-2012 03:35 AM
no hot water only cold in bathroom shower ArtOfShred87 General Plumbing Help 5 05-28-2011 11:47 PM
NO HOT water in second floor bathroom after..... klatimer Showers and Tubs 2 05-02-2011 01:18 AM
Hot water from bathroom sinks. Chris General Plumbing Help 7 12-28-2010 04:15 PM
Water in bathroom exhaust vent magikal General Plumbing Help 4 03-31-2010 03:12 PM
Newest Threads
