Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Weeping Solder Joint
Thread Tools Display Modes
Old 11-02-2013, 01:47 AM   #1
spaxz
Default Weeping Solder Joint
Hello,
I soldered in a shower tap and head today, when I turned the water on I noticed the 1/2" copper pipe had a slight beed of moisture on it where it is soldered to the top of the shower tap (pipe goes to shower head). There was also a small beed of moisture half way up the shower head pipe (top of soldered collar).
Now I can remove, replace and resolder the collar but what do I do about the weep on the top of the tap.
Do I heat it up, remove the pipe, clean best I can and resolder?
Thanks
spaxz is offline
Old 11-04-2013, 06:35 PM   #2
Mr_David
Easily Amused
Mr_David's Avatar
Liked 769 Times on 622 Posts
Likes Given: 535
Best to take it apart , clean it and solder it again
Solder joint leaks are often caused by burning the flux, to much heat on one side while soldering. If the flux is burned it won't take the solder. Easy on the heat makes a nice joint
a.k.a. Krazedav
Mr_David is offline
Old 11-04-2013, 06:37 PM   #3
Mr_David
Easily Amused
Mr_David's Avatar
Likes Given: 535
PS I'm back ,,,, I'll try to stop in more often.
a.k.a. Krazedav
Mr_David is offline
People Like This
ABS Vent Pipe Joint Leak Patrick1234 Showers and Tubs 4 05-14-2013 02:09 AM
Caulked a joint for the first time oakumboakum General Plumbing Help 26 12-09-2011 01:41 PM
no- solder joints sharkbite connections bucktooth General Plumbing Help 2 11-25-2011 01:45 AM
solder 220ws General Plumbing Help 4 10-01-2011 06:57 PM
60/40 Lead Solder for Copper Pipes Ravenwoods General Plumbing Help 3 09-19-2011 04:00 PM
Newest Threads
