Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Electric water heater for space heating
Thread Tools Display Modes
Old 10-04-2013, 03:12 AM   #1
Christoph
Christoph's Avatar
Liked 5 Times on 4 Posts
Default Electric water heater for space heating
I have recently come across a couple of radiant heat systems that are being heated using a 50 gallon electric water heater. Is this legal? Is this ok to do according to code? The systems I have seen have been working fine for years, I was just wondering if this as ok to do or not.
Christoph is offline
Old 10-04-2013, 03:18 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 722 Times on 546 Posts
Likes Given: 615
As long as the demand for heat is low enough that the heater can supply it, it should be fine. It may be a little costly to run. You would be better off if it was a gas heater.
John
johnjh2o is offline
Old 10-04-2013, 03:27 AM   #3
Christoph
Christoph's Avatar
Thanks for the quick reply! Actually electric is one of the cheaper ways to heat our homes in my area, as we run off of hydro power and don't have natural gas. I know that they work in the examples I have seen, but my biggest question was whether or not it was code. My local inspector wasn't sure if it was ok to use an appliance that is listed for potable water heating for a closed loop heating system. Thoughts?
Old 10-05-2013, 02:58 PM   #4
chukar
Liked 20 Times on 18 Posts
As long as it has a double wall heat exchanger inside of it, then yes I would be legal, if its a regular electric with no separate heat exchanger then probably not. Attached is the Laars with a picture of what I mean
http://www.laars.com/LinkClick.aspx?...-acRwm8%3D&...
There is always the possibility that someone could come put chemicals into the system, also the reason they prefer a proper back flow device on the feed for it.
chukar is offline
Old 10-05-2013, 03:12 PM   #5
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
I'm not promoting this specific manufacturer, just using the images on the site as an example that there are electric indirect water heaters for hydronic systems on the market, since you don't have natural gas as an option.
http://www.heat-flo.com/prod_indirectWaterHeater.html
Caduceus is offline
Electric water heater problem? elmaur Water Heaters and Softeners 5 01-11-2015 10:02 PM
Hot Water Heater in Crawl Space Help rjm102478 Water Heaters and Softeners 14 10-13-2012 01:51 PM
Problem with hot water tank that is used also for space heating curt1s General Plumbing Help 1 02-22-2011 02:21 AM
Electric Hot water heater montel General Plumbing Help 3 01-22-2011 02:53 AM
Sound From Electric Water Heater eaglesclaw121 Water Heaters and Softeners 3 10-18-2010 09:25 AM
Newest Threads
