Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Red Residue in shower and sink aerator etc.
Thread Tools Display Modes
Old 08-09-2013, 03:11 AM   #1
jessb_55
Default Red Residue in shower and sink aerator etc.
Ever since I bought my house about 3 years ago I've had issues with hard water, etc. Originally the house had a Kenmore water softener which from what I've read aren't that great. So I replaced it with a brand new Fleck Ecominder 5600.
Well the new model seems to be doing better with the water hardness, however I've noticed that we get a lot of red residue in the shower grout, on the facet aerators. Does this mean we have a lot of iron? If that's the caxe I would have thought we would have issues with rust which we don't have at all.
Also our white clothes really loose their white color, almost makes them brown/gray after multiple washes.
Any advice would be great! Would some softener salt with Rust Remover be beneficial at all?
jessb_55 is offline
Old 08-09-2013, 01:49 PM   #2
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 206 Times on 187 Posts
Likes Given: 46
The first thing to do is have the water tested before your softener. See how much iron you have. More than likely you will need an iron filter along with the softener to get rid of the iron. Softeners do remove some iron, but not all of it. It only takes a minute bit of iron to stain. Iron also fouls the media bed in the softener.
speedbump is offline
LiQuId Likes This
Old 08-12-2013, 03:38 AM   #3
jessb_55
speedbump, I'll test the water and let you know! As far as the iron Filter is that a while separate system and is that something that I could possibly install myself, and how much are we looking at in cost?
THANKS
jessb_55 is offline
Old 08-12-2013, 01:24 PM   #4
speedbump
speedbump's Avatar
Likes Given: 46
If you can do a little plumbing, you could install it yourself. It's simply in and out with a drain line. It uses air instead of chemicals to oxidize the sulphur and iron. Cost for a 1" bypass, 12x52 black tank, Fleck 2510 Air injected valve, Top & bottom distributors along with two cubic feet of resin is around $900.00.
Old 08-27-2013, 02:36 AM   #5
jessb_55
Hey Speedbump-
I finally got around to picking up another test kit.. Here are the results:
ph: 6.5
total alkalinity:240
total chlorine: 1
total hardness: inbetween 120 and 250
iron: 0
Copper: 0
Nitrate: 1
Nitrite: 0
granted I just noticed now that you said to test the water before the softener, which I didn't do.
Anyway, our Iron level is so low it was basically non-existent, so now what are your thoughts?
Thanks!
jessb_55 is offline
Old 08-27-2013, 01:51 PM   #6
speedbump
speedbump's Avatar
Likes Given: 46
I would like to see the PH a little higher, but if you have no iron, it's not a problem. It will get all the sulphur gas.
Redo your test before the softener. I just need the hardness in either PPM or Grains. Re test the PH too. Since it's after the softener, check the iron too just for the heck of it.
Old 08-28-2013, 02:39 PM   #7
jessb_55
So redo the PH, hardness and Iron test before the softener?
Not to sound dumb but how do I access the water before the softener? Or do I just put the softener into bypass?
thanks!
jessb_55 is offline
Old 08-28-2013, 03:01 PM   #8
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
Likes Given: 1
A hose bib shouldn't be hooked into your softener. The softener would kill your plants...
camaroderrick73 is offline
stevemachine Likes This
Old 08-29-2013, 12:38 PM   #9
jessb_55
Camaroderrick I have no idea what you're talking about lol
jessb_55 is offline
Old 08-29-2013, 01:23 PM   #10
speedbump
speedbump's Avatar
Likes Given: 46
I forget, not everybody in the US has their tank in the back yard like here in Florida. If you don't have a hose bibb before the softener somewhere, you may have to put it in bypass and let it run for at least ten minutes to be sure you're getting a raw sample.
How to prevent food residue build-up and clog q0987 Drain and Sewer Cleaning 10 01-27-2013 10:35 PM
In-tank septic aerator vs outside air pump? JonnieBlaze Septic Tanks 1 10-09-2012 02:32 AM
aerator adapter jeb820 General Plumbing Help 3 09-26-2012 02:34 AM
Aerator on Delta Faucet jcaguon2001 General Plumbing Help 1 07-13-2011 01:53 PM
Sulfur odor, black residue in toilets. BringingChaos General Plumbing Help 6 04-13-2011 01:19 PM
Newest Threads
