Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Water Hammer Arresters
Thread Tools Display Modes
Old 03-21-2013, 06:12 AM   #1
mcintoshmc
Default Water Hammer Arresters
I will be repiping the house from galvanized to copper. Do people install these arresters if they experience water hammer, or a head of time as a preventative measure? If so, where should I put them as a preventative measure?
Also, I've read that they should be large than the supply line. Now am I teeing off the riser, or off the actual supply line?
mcintoshmc is offline
Old 03-21-2013, 11:09 PM   #2
IFIXH20
HERE TO HELP
Liked 192 Times on 157 Posts
Likes Given: 137
You can use a laundry box & Ice maker box with the arrestor as part of the valves. Also install arrestor under kitchen sink for dishwasher. When plumbing to other fixtures (tub/shower valves, faucets, toilets) tee off risers with air chambers ( chambers 12'' -- 18'' long).
IFIXH20 is offline
Old 03-22-2013, 12:30 AM   #3
PioneerPlumber
:0)
PioneerPlumber's Avatar
Liked 21 Times on 21 Posts
Likes Given: 5
These are usually only needed where a solenoid valve is located. Examples are dishwashers, washing machines and ice makers.
The photo showed one that can be fastened to a washing machine bib
-Daniel
PioneerPlumber is offline
phishfood Likes This
Old 03-22-2013, 03:08 AM   #4
mcintoshmc
So, in my case I would only need one on the hot/cold washer, cold for dishwasher, and one for the spigot in the backyard used for my sprinklers. Are they supposed to be same size of pipe or 1 size bigger. I read they should be bigger. Meaning 3/4 arrester on 1/2 line?
Old 03-22-2013, 03:11 AM   #5
phishfood
Liked 481 Times on 392 Posts
Likes Given: 647
I generally use the same size arrestor as the line that it is serving.
Lake County, Florida plumber
Springtime Plumbing Services, LLC
License #11067533
352-630-5673
phishfood is offline
IFIXH20 Likes This
Old 03-22-2013, 03:11 AM   #6
mcintoshmc
I also read those air chamber weren't good because I would constantly have to drain after the pipe fills up with water. Is that accurate?
Old 03-22-2013, 03:21 AM   #7
IFIXH20
HERE TO HELP
Likes Given: 137
You shouldn't have any problems with air chambers
IFIXH20 is offline
Old 03-22-2013, 03:28 AM   #8
IFIXH20
HERE TO HELP
Likes Given: 137
You need arrestor at the laundry, fridge, and hot water to dishwasher. sprinklers usually do not slam off
IFIXH20 is offline
Old 03-22-2013, 03:30 AM   #9
stevemachine
stevemachine's Avatar
Liked 90 Times on 78 Posts
Likes Given: 92
In my area that aren't allowed to be used, but depends on codes in your area. We are required to use hammer arresters and not the air chambers. Technically speaking if you drained your system every once in a while (maybe yearly) I think air chambers would work, but I'm not certain on the air chambers.
stevemachine is offline
Old 03-22-2013, 03:47 AM   #10
IFIXH20
HERE TO HELP
Likes Given: 137
You can also use these for the washer,ice maker & dishwasher
1st = washer
2nd = ice maker
3rd = dishwasher
IFIXH20 is offline
PioneerPlumber Likes This
basement toilet water hammer abfab Toilets and Sinks 0 07-29-2011 01:15 AM
Water hammer trouble Komodo General Plumbing Help 7 05-13-2011 12:54 AM
water hammer at washing machine only... k5ranger General Plumbing Help 5 02-22-2011 10:08 AM
Water Hammer opsuv83 General Plumbing Help 4 02-20-2011 10:50 PM
Water Hammer DennisF General Plumbing Help 20 07-30-2010 05:53 PM
