Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Installing flexible copper pipe to water heater
Thread Tools Display Modes
Old 03-20-2013, 06:00 AM   #1
mcintoshmc
Established Member
Default Installing flexible copper pipe to water heater
I will be replacing the galvanized pipe from my water heater with the flex copper pipe. Any install advice?
mcintoshmc is offline
Old 03-20-2013, 11:33 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
They're OK but for flexible connections I prefer the braided ones.
John
johnjh2o is offline
Old 03-20-2013, 01:58 PM   #3
mcintoshmc
Established Member
Any tips installation wise?
I know, I'll be cutting off water. Do, I have to shut off gas? I wouldn't think so
Do I have to drain?
Old 03-20-2013, 02:16 PM   #4
johnjh2o
johnjh2o's Avatar
Likes Given: 620
Other than avoiding kinking the supplies, it's straightforward.
John
johnjh2o is offline
Old 03-20-2013, 06:41 PM   #5
mcintoshmc
Established Member
But do I have to drain?
Old 03-21-2013, 01:21 AM   #6
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
Not the entire heater, no. Just drain the pressure off before unhooking or cutting anything. If your water piping is ran overhead, drain as much as possible out by opening all of the faucets and shower valves at the same time.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
hot water copper supply pipe is noisy eagleslincoln General Plumbing Help 2 01-24-2013 07:13 PM
Can I remove this pipe next to water heater? lucymiella Water Heaters and Softeners 14 09-07-2012 12:39 PM
What is this 2nd copper water pipe for? menudoboy General Plumbing Help 5 01-27-2012 08:04 AM
Water heater pipe leaks prematurely thezman General Plumbing Help 9 06-29-2011 04:50 AM
Switching From Natural Gas To Electric Water Heater...What To Do With Gas Pipe/Valve? Abraham General Plumbing Help 3 05-14-2010 02:31 PM
Newest Threads
