Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Project Display > Gas meter tie in
Thread Tools Display Modes
Old 02-28-2013, 12:57 AM   #1
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
Default Gas meter tie in
This is a project that has been going on for awhile. There's two separate gas systems here, one to service the generator and exterior lighting, and another to service the future residence. The gas piping is only part of the project, but I thought that this particular section was especially photogenic.
Palladio gas meter piping 1.jpg   Palladio gas meter piping 2.jpg   Palladio gas meter piping 3.jpg   Palladio gas meter piping 4.jpg   Palladio gas meter piping 5.jpg
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 02-28-2013, 03:24 AM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
Looks good! Is galvanized pretty typical? I've never used it up here, only saw it in service for water and drainage in old homes. We pretty well only use black iron with the black lacquer finish
stevemachine is offline
Old 02-28-2013, 04:09 AM   #3
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
Is that valve going to cause electrolysis?
Chris is offline
phishfood Likes This
Old 02-28-2013, 04:46 AM   #4
stevemachine
Likes Given: 97
I think technically it should however whenever I've put in gas lines we've always used brass ball valves with black iron piping which should be the same idea. Good point though, I've never had an issue or came across that before.
Old 02-28-2013, 05:13 AM   #5
Chris
Administrator
Chris's Avatar
Likes Given: 67
I think it would effect water pipe more but in theory i guess it could rot it out quicker. They don't make a Galv gas valve do they?
Chris is offline
Old 02-28-2013, 02:53 PM   #6
stevemachine
Likes Given: 97
Not that I've seen, I've only saw brass ones but you never know haha. Electrolysis could happen technically according to the nobility of the metals but they do claim brass shouldn't be subject to it. I think over a period of time it could happen no doubt. And yeah water lines I've saw brass FIPs and galvanized have electrolysis
Old 02-28-2013, 02:53 PM   #7
stevemachine
Likes Given: 97
On water heaters
Old 03-01-2013, 12:11 AM   #8
phishfood
Administrator
Likes Given: 1739
I know with water flowing through the lines, electrolysis is an issue. To the best of my knowledge, a closed system such as a heating system does not really suffer from that as much as an open system that always has fresh water introduced to it.
So considering that this is a gas system, I am not concerned with electrolysis. It is common practice to use brass valves on gas systems, either with black steel or galvanized.
People Like This
Old 03-01-2013, 01:22 AM   #9
stevemachine
Likes Given: 97
Yeah the flow on the gas line probably wouldn't be enough to cause electrolysis, but the water lines make sense.
Old 05-01-2013, 10:53 PM   #10
kaufman
In Massachusetts it is illegal to use galvanized fittings or pipe in natural gas systems
JK
kaufman is offline
Water Meter Going Backward tranelch General Plumbing Help 16 07-07-2013 02:29 PM
Speakman Mix O Meter tallpaul Showers and Tubs 1 01-27-2013 05:29 PM
Connecting Water Meter BLG General Plumbing Help 6 09-07-2012 07:23 PM
Meter Gauge for Private Well ku2 Pumps and Wells 5 10-08-2011 01:42 PM
Flush O Meter icelikeaninja General Plumbing Help 4 04-06-2011 02:27 AM
Newest Threads
