Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Basement Shower Drain Question (with pic)
Thread Tools Display Modes
Old 01-24-2013, 12:15 AM   #1
bradcss
Default Basement Shower Drain Question (with pic)
The attached pic is the shower/bath drain that was roughed in when our house was built in 2006, and I'm trying to figure out what this is & how to use it. I know it's a drain rough-in (duh), and the pipe is metal with a 2" inside diameter and full of concrete (at least at the top of it). I thought most plumbing was PVC, so this metal pipe and the red base is throwing me. Do you suppose this drain pipe is metal and it is metal all the way to where it links up to sewer drainage? Or do you think this metal pipe is just a cap that needs removed somehow to reveal a PCV drain pipe. If the metal pipe is permanent then I guess I'll just need to cut it off at the appripriate height once the shower base arrives.
I will be installing a shower base over the pipe, but I really want to understand what the deal is with this pipe before w begin. Thanks for any input, and yes I am hiring a licensed plumber to run all the water lines...I'm just doing some of the easier things to save some $$$ and to learn.
bradcss is offline
Old 01-24-2013, 12:41 AM   #2
stevemachine
stevemachine's Avatar
Liked 90 Times on 78 Posts
Likes Given: 92
I can't see the pic, might not of worked when you tried to attach it. Once we can see it I'm sure we can help ya out
stevemachine is offline
Old 01-24-2013, 01:28 AM   #3
phishfood
Liked 477 Times on 389 Posts
Likes Given: 638
I don't see the picture either.
Lake County, Florida plumber
Springtime Plumbing Services, LLC
License #11067533
352-630-5673
phishfood is offline
Old 01-25-2013, 01:23 AM   #4
bradcss
sorry...here is the pic...
bradcss is offline
Old 01-25-2013, 01:37 AM   #5
stevemachine
Likes Given: 92
Looks like cast iron. You can adapt to it with one of those rubber neoprene donuts if I'm not mistaken. Someone else will probably chime in there's a better plan
Old 01-25-2013, 09:46 AM   #6
johnjh2o
johnjh2o's Avatar
Liked 397 Times on 318 Posts
Likes Given: 253
That is cast iron and it is the same OD as PVC or ABS plastic. It will fit your shower strainer. It just needs to be cut to the proper height. It should be connected to a trap. What I would do to be sure there is a trap is to pour some water into the pipe then check to be sure that it is holding water. The red spacer in the floor is there to allow the shower strainer to recess into the floor.
This is providing it is a 2" line and not 3" or 4". If it's the larger size it'as for a toilet.
John
johnjh2o is offline
My basement shower drain. Is it up to code? bomland Showers and Tubs 7 08-20-2012 11:52 PM
basement shower srw Showers and Tubs 4 08-18-2012 10:47 PM
Tub shower with 1 1/2" drain to p trap question yzman720 General Plumbing Help 2 05-10-2011 01:54 PM
Basement pipe question timmer General Plumbing Help 4 03-15-2011 06:09 PM
Basement Venting Question kev General Plumbing Help 2 01-20-2010 11:34 PM
