Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Weird Pump Issues
Thread Tools Display Modes
Old 01-19-2013, 11:19 PM   #1
kmarine0120
Default Weird Pump Issues
Ok, here is the deal I bought some land that had a reservoir and well pump already on it. Ever since we put our house here and started using the well we have had nothing but issues. The primary problem is that the 3/4 hp pump keeps ejecting itself off the houses feed pipe. The first time I went down and looked at it, it had one clamp on it so I put on two and it worked for a month or so but not it is back to its old ways. I have changed the flexible piping with hard pvc hoping that would work better and it did for a month or so before blowing it off again. This time however when I go down there the pump is running but when I turn off power to hook it back into the pipe it wont come on for a longgggg time before blowing it off the pipe again.
How can one fix the problem of the pump blowing off the pipe I am now up to three clamps with no luck. Also is the pump the wrong type the reservoir is only 600 gallons and the pump pretty much touches the bottom of it but it has to push water about 300 ft mostly uphill. And why does it take so long to come back on is there a fail-safe that is causing this.
Sorry to be so full of questions but I am getting a bit tired of having to screw with my well.
kmarine0120 is offline
Old 01-20-2013, 02:55 AM   #2
waterwelldude
Water well,and septic guy
waterwelldude's Avatar
Liked 4 Times on 4 Posts
Likes Given: 1
Do you have a tank and pressure switch?
Edit Signature
waterwelldude is offline
Old 01-20-2013, 05:23 AM   #3
kmarine0120
Yes the tank and pressure switch is at the house
Old 01-20-2013, 12:16 PM   #4
phishfood
Liked 517 Times on 416 Posts
Likes Given: 693
Does the clamp hold the hose onto a barbed fitting, or smooth pipe?
I am not all that keen on hose clamps as an attachment method for pressure pumps to start with.
Lake County, Florida plumber
Springtime Plumbing Services, LLC
License #11067533
352-433-1912
phishfood is offline
Old 01-20-2013, 03:04 PM   #5
kmarine0120
Its on one of those grey pvc adapters with the barbs
Old 01-20-2013, 11:06 PM   #6
Valveman
Pump Controls Tech
Valveman's Avatar
Liked 12 Times on 9 Posts
You need the extra long brass or Stainless barb connectors so you have plenty of room for two or three clamps. But you could just have a water hammer issue. Try removing any check valves in the system except for the one that is on the submersible pump. This will eliminate water hammer on pump start. Or since it is a plastic barb fitting you could have a heat problem if the pump is running dry or not shutting off when it should.
www.cyclestopvalves.com
Valveman is offline
Old 01-21-2013, 02:35 AM   #7
Beni
Liked 15 Times on 14 Posts
How high is the hill. Sounds like your static pressure, that is the head of water between the pump and house is high. If your house is say 150' vertical above the pump then the static head would be 65 psig. Add dynamic pressure, that is the pump discharge pressure and you might be exceeding the working pressure of the fitting.
Beni is offline
Old 01-21-2013, 02:07 PM   #8
speedbump
Water well and pump tech
speedbump's Avatar
Liked 56 Times on 53 Posts
Likes Given: 14
I believe you have a jet pump from your description and you said the switch is with the tank at the house. So did you mean that the pump and switch are separated by several hundred feet? If so, that could be a large part of the problem. Water hammer from the pump kicking on and off rapidly when the tank fills could be enough to beat the pipe off the barb fitting. And plastic fittings are not the approved method. You need to get the pump and switch next to one another along with the tank.
speedbump is offline
Old 01-25-2013, 12:22 AM   #9
waterwelldude
Likes Given: 1
Quote:
The pump doesn't care where the tank is. That would not make any difference. The switch and the tank are the ones that need to stay together.
{As far as water hammer is concerned)
Edit Signature
Old 01-25-2013, 01:45 PM   #10
speedbump
speedbump's Avatar
Likes Given: 14
Your absolutely right. I don't know why I mentioned the pump in that statement.
phishfood Likes This
Friend has weird connection to drain line w/ pump? ardcarmvk Water Heaters and Softeners 1 06-05-2012 04:23 AM
Weird mounting nut Springerrr General Plumbing Help 7 01-30-2012 03:35 AM
Weird Shower Issue colobsktldy General Plumbing Help 2 04-26-2011 02:20 AM
weird one...who's ready for it? kevbocometh General Plumbing Help 1 12-09-2010 04:14 PM
Pump issues. Septicissue Pumps and Wells 4 01-15-2010 02:33 PM
