Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Toilets gurgling... what's wrong here?
Thread Tools Display Modes
Old 01-13-2013, 08:19 AM   #1
funperro
Default Toilets gurgling... what's wrong here?
Hey guys, thanks in advance for any help.
The situation:
Two nights ago, the bathtub in the second story bathroom was used and fully drained all at once. I happened to be near the main floor bathroom and I heard the toilet gurgling/bubbling at some point during the tub draining. I could see large air bubbles coming out into the bowl. I tried flushing this toilet and the water wouldn't go down (raised up to near the top of the bowl). I grabbed a plunger and tried to plunge on it a few times and it did not go down. In the past, when this toilet flooded it would be extremely easy to plunge. I left the bathroom and came back about 5 min later.. the toilet was completely empty of water. Fast forward to today... as I took a shower (again, upstairs bathroom but not the same upstairs bathroom as the bathtub) I could hear the toilet gurgling/bubbling.
So far, I haven't seen any bad repercussions (water on the floor, ceiling, carpet, etc) but I am getting nervous something may be on the way soon... which is why I need your help. What could be the problem here? To me it seems like it is either a) an issue with the main sewer line or b) an issue with the venting in the house (possibly plugged?). I certainly could be wrong there.. and am hoping to get some suggestions on how I can diagnose between the two possibilities or potentially other possibilities that I hadn't thought of.
Thanks!
funperro is offline
Old 01-13-2013, 01:28 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
You have a stoppage in the main line. The line needs to be snaked.
John
johnjh2o is offline
phishfood Likes This
Old 01-13-2013, 05:32 PM   #3
funperro
I'm on city. I've got a snake but have never snaked the main line before. Is this a DIY project or better suited for a plumber's setup?
funperro is offline
Old 01-13-2013, 07:02 PM   #4
johnjh2o
johnjh2o's Avatar
Likes Given: 620
If you have the proper equipment and the skill to use it then have at it. If not then call a plumber. Keep in mind you could get injured with the size machine that is needed to clear a main line.
John
johnjh2o is offline
Old 01-14-2013, 03:44 AM   #5
funperro
Plumber was here for two hours tonight. Did 4 runs.... two with a 'large' blade and 2 with a smaller blade. There was an obstruction near the turn at the city line... so he thinks. He could hear water sloshing around somewhere between 5 and 20' just outside the house (his starting point was at the access in my basement). Probably a belly... but hopefully not major. Ugh. I'm running a camera tomorrow to better understand the issue but at this point I have no idea what it is and the partial block is getting worse.
funperro is offline
Old 01-14-2013, 07:28 PM   #6
funperro
OK so for an update: the camera crew was just here and they said 'sorry we can't see anything since the line is still full'. Now they're bringing another crew out to work the line again (snaking). Yay. So far I've only had to pay for the camera crew ($150)... they didn't charge for the first snaking so that I guess was nice. The guy said "It looks to be a major problem but who knows we'll see".
funperro is offline
Old 01-15-2013, 03:18 AM   #7
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
Yeah usually in my experience I've augered the drains before that ended up being collapsed and after probably a few hours of augering/camera I have a pretty good idea of whether or not the line is collapsed just by feel. If they do say it is collapsed I would just make sure you get a few quotes on line replacement. Just ensure that the company you called is reliable. I hate seeing people get screwed/lied to. From a homeowners perspective theirs no easy way to tell between a collapse or a blockage its all up to the plumber to figure out for ya. Best of luck! Keep us updated
stevemachine is offline
Old 01-15-2013, 03:45 PM   #8
funperro
OK another update: so after the camera, they sent out a "Very experienced" plumber to try and re-snake the line. He worked it for 1.5hrs. He first used a 1.5" diameter blade and was able to get all the way to the city line, but it was 'tight' starting at 60' and "tighter" at about 80'. He then replaced the blade with a larger 3" diameter blade and it was easy going until about 80'. He worked that same spot at 80' for 15 min and was never able to move an inch.
Unfortunately, neither the 1.5" blade or the 3" blade were able to clear the issue enough to actually drain the pipe. So again, I was dealing with a pipe that most likely was still filled with sewage which would prevent camera inspection. Indeed, we went back in with a camera, just in case... but were still unable to see anything since it was still sewage-filled. Today, I'm receiving bids to do a short spot repair at the area where the camera couldn't get in. I'd have them add a cleanout access at that spot, then we'd have much more torque available to hopefully be able to get in and clean it enough to get a camera in. At that point, I'd have a better indication of what the problem is so I could get on with fixing it asap. Thoughts? By the way, the distance from where the new access point to the city tap would be about 25'.
funperro is offline
Old 01-15-2013, 06:47 PM   #9
stevemachine
Likes Given: 97
Well in my opinion I've been able to clear drains that are past 100 ft from the house cleanout. They should be able to clear the drain from the house, at least with my experience. Even if its packed with sewage the blade should be able to cut through it regardless. And I've augered drains that have taken hours of augering to clear it out. Again its hard to tell without being there in person. I would a little bit weary of what they are suggesting cause the only time I've had to dig was because the line was collapsed, otherwise I was able to clear it. There's a chance its collapsed. Any idea of the material of piping for your sewer?
Old 01-19-2013, 12:51 AM   #10
DetroitRob
DetroitRob's Avatar
Liked 11 Times on 11 Posts
If you can poke through, and have pitch, you should be able to inspect most of the line. I've even run my snake with my camera at the same time.
DetroitRob is offline
Gurgling and slow draining. Korndogg Drain and Sewer Cleaning 1 06-12-2012 02:14 AM
Loud gurgling from sink/tub when washer empties. tireshark General Plumbing Help 3 04-24-2012 01:16 AM
Will air gap eliminate gurgling from single bowl sink flyer22 Toilets and Sinks 5 03-17-2012 12:07 AM
Toilets- Can I put 2 toilets back to back on a double tee? markcool General Plumbing Help 14 11-02-2011 11:42 AM
Gurgling toilet Septik General Plumbing Help 4 03-22-2010 12:24 PM
Newest Threads
