Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > PEX Homerun System Setup??
Thread Tools Display Modes
Old 12-01-2012, 02:29 AM   #1
mcintoshmc
Established Member
Default PEX Homerun System Setup??
Someone suggested the home run system, and after doing some research, I really like that setup. So, this what I got so far.
Guest Bathroom
Shower - 1 Hot/1 Cold
Sink - 1 Hot/1 Cold
Toilet - 1 Cold
Washer/Dryer
1 Hot/1 Cold
Kitchen
Sink - 1 Hot/1 Cold
Dishwasher - 1 Hot
Master Bathroom
Sink - 1 Hot/1 Cold
Toilet - 1 Cold
Water Heater
1 Hot/1 Cold
Front/Back Yard Spigot
2 cold
TELL ME IF MY THINKING IS CORRECT
I found a 24 port manifold.
1- Blue 3/4 PEX line from water meter to manifold cold water main
2- 1/2 Blue line from manifold to water heater
3- Red line from manifold hot water main to water heater
4- Then 1/2 red and blue lines from manifold to each fixture
QUESTIONS??
1) Based on what I described, 3/4 will be coming in from the meter, but 1/2 to the water heater, yet it will be 3/4 from the water heater to the manifold. Doesn't make sense to me. Can you explain?
2) There will be ball valves for each port, where do people normally place the manifold, so it is accessible?
3) Did I miss anything?
mcintoshmc is offline
Old 12-01-2012, 03:01 AM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
I would suggest 3/4 to the water heater. Tee off of the pex from the meter. Electric or gas heater? If its gas you can't run pex to the water heater because anything combustible needs to be six inches away from the vent, unless its b vent its 1". Also dishwasher I would tee off the hot under the kitchen sink, you don't have to run a seperate hot for the dishwasher. Other than that I think you pretty well got the idea down pat.
stevemachine is offline
Old 12-01-2012, 03:02 AM   #3
stevemachine
Likes Given: 97
And if I remember correctly you are in a crawl space right? Usually people put a header in the joist space, at least that's where I've always put mine.
Old 12-01-2012, 03:04 AM   #4
stevemachine
Likes Given: 97
Also not sure if you ever plan to add fixtures in the future but some people go with headers with extra ports then cap them off, that way if you want to add something you can still go off the home run system.
Old 12-01-2012, 03:29 AM   #5
mcintoshmc
Established Member
Quote:
Gas. So, I currently have galvanized to the heater. I think I'll have to run pex to copper, to keep it 6 inches a way.
Old 12-01-2012, 03:32 AM   #6
mcintoshmc
Established Member
When you say header, you're talking about the manifold right? And if you put it in a joist space, then that means you have to go under the house to shut off water right? How close should the header be to the water heater?
Old 12-01-2012, 05:32 AM   #7
stevemachine
Likes Given: 97
Quote:
Ok good call! I've seen people run plastic pipe less than six inches to the vent but its not worth the risk.
Old 12-01-2012, 05:39 AM   #8
stevemachine
Likes Given: 97
Yes, header is a manifold. That would be correct. You can really put it wherever you want. I figure as much as it sucks, if you do it in the crawl space then once you drill your holes from the floor it's not bad to run. If ya put the header upstairs then it may involve drywall. And usually headers are within a few feet of the tank. There's no particular rule for that, that I know of. How far are your runs? Like what's your longest? Just a ball park, out of curiosity.
Old 12-01-2012, 05:49 AM   #9
mcintoshmc
Established Member
Still haven't decided completely where to put the manifold, that's the toughest part for me, but the longest run from the heater is about 35 feet
Old 12-01-2012, 06:13 AM   #10
stevemachine
Likes Given: 97
Ok well I mean for the placement of the header you just gotta try and think of the whole picture, the main thing is, put it in a spot where you can do all of your take offs easily, like do it in a wide open joist space. Ah I usually figure the fine details out once if got the header in my hand. But maybe that's just me
System Design TheNapster87 Plumbing Building Code 7 12-20-2012 10:46 PM
Sealed system JakeAdlard General Plumbing Help 1 09-08-2012 12:25 PM
DIY sprinkler system Barber General Plumbing Help 20 03-23-2011 12:32 PM
PEX manifold system bradthebard Project Display 5 04-06-2010 12:15 PM
Detention system Chris Project Display 4 01-09-2010 03:34 AM
Newest Threads
