Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Septic Tanks > In-tank septic aerator vs outside air pump?
Thread Tools Display Modes
Old 10-08-2012, 06:47 PM   #1
Default In-tank septic aerator vs outside air pump?
I just bought a house and the septic system needs a new aerator. The septic tank has three chambers. The middle chamber used to have an in-tank aerator that sat in the tank riser with the long shaft going down into the chamber to stir the contents and supply air. This aerator was removed from the tank when the previous owner passed away because the house was going to sit vacant for a while. The cleaning crew mistakenly threw the aerator away while cleaning up.
I'd like to know if I need to go with this style aerator (which has many disadvantages from what I've read) or if I can go with the style that just puts an air diffuser in the tank to supply the oxygen needed with the pump located outside the tank.
The disadvantages seem to be higher monthly electricity costs (estimated $20 per month more), more potential for problems due to being located in the tank, possibly less I could repair if something did go wrong (the external pumps have rebuild kits you can buy).
Just need some opinions on this. I like the fact that the external pump runs on less amps and will save money each month ontop of being more easily repaired. But I don't know if it will work correctly for the setup this house has and no local sewer folks have been able to answer this question yet.
JonnieBlaze is offline
Old 10-09-2012, 02:32 AM   #2
By the way, the 'outside air pumps' I'm referring to are things like SepticGenie, SepAerator, and SepticairAID. They all work basically the same (SepticGenie is the most expensive but also seems to disperse the air differently and maybe more productively). They appear to do the same thing the old in-tank aerator did (such as the Ulta-Air 535), just differently, a bit cheaper, but without the stirring effect.
floating septic tank IFIXH20 Septic Tanks 11 06-30-2012 12:45 PM
Septic tank question.. rtlplumbing Septic Tanks 2 03-21-2012 06:06 PM
Septic Tank - baffled jreist Septic Tanks 9 09-21-2011 08:29 PM
How big is my septic tank? Mania64 Septic Tanks 5 05-25-2011 07:41 AM
Septic Tank Leak jmrardin General Plumbing Help 2 03-09-2010 12:57 AM
Newest Threads
