Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Leaking Drain in Upstairs Shower
Thread Tools Display Modes
Old 06-07-2012, 10:58 PM   #1
dbdezyne
Default Leaking Drain in Upstairs Shower
Recently found a leak in our ceiling and was able to trace it to the drain in the upstairs shower. The drain in the shower is a Caspers 101-P. My first suspicion is that the leak is coming from where the top of the drain flange meets the shower opening. There appears to be a very small gap there where I think water can get through. My question is this type of drain threaded or glued? If it is glued, then it appears that the whole shower has to come out, but if it is threaded, then maybe just the Caspers drain can be pulled and replaced. Any ideas or help would greatly be appreciated.
dbdezyne is offline
Old 06-07-2012, 11:18 PM   #2
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
Either way, you will have to access the bottom of the shower base to remove the old drain. That is, if I understand you correctly that this is a fiberglass shower stall or shower base. These type drains are all secured to the shower by a large nut on the bottom of the shower base. Whether or not the drain glues to the pipe or uses a rubber compression gasket is a small matter compared to getting to the bottom of the shower.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 06-07-2012, 11:37 PM   #3
dbdezyne
Yes, this is a complete fiberglass stall. So, your take is that I've got to cut a hole in the ceiling to replace or repair the drain? I've seen a couple of videos where the drain is screwed in and the rubber gasket is replaced from the top, then the new drain installed. That was why I was asking if this would be a threaded drain.
dbdezyne is offline
Old 06-08-2012, 12:20 AM   #4
phishfood
Administrator
Likes Given: 1739
The standard drain with a rubber gasket also has a large nut on the bottom that unthreads.
However, I have seen one of our most experienced members, johnhh2o, post recently about a replacement drain that can be installed directly from the top. I have no experience with it, and cutting the old drain off, while doable, would still be a problem.
Old 06-08-2012, 01:27 AM   #5
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
This is the strainer phishfood is referring to. But like he said it is doable but removing the old strainer takes some experience.
http://www.wingtite.com/print-instructions/
John
johnjh2o is offline
Old 06-08-2012, 01:40 AM   #6
dbdezyne
Yeah, that's what I saw advertized. There is a back wall of the shower that I can get to. I was wondering if I could cut a small inspection hole at the bottom to see if that drain is threaded or not. If it is, then I may be able to get something in from that direction to loosen the nut and remove the drain without coming in from the bottom. Otherwise, this could be a complete shower removal.
dbdezyne is offline
Old 06-08-2012, 01:50 AM   #7
johnjh2o
johnjh2o's Avatar
Likes Given: 620
Is the gap your seeing between the shower and the strainer or between the gasket and the strainer? If it's between the shower and the strainer the only fix is to replace the strainer. Coming in from the back wall will do nothing for you.
John
johnjh2o is offline
Old 06-08-2012, 03:02 AM   #8
dbdezyne
I'll post a pic tomorrow that shows the gap.
thanks
dbdezyne is offline
Old 10-11-2012, 03:13 PM   #9
dbdezyne
Finally got some time to look at this drain leak. Here are a couple of pictures of the drain. Basically, still not sure if this a threaded type that can be removed from the top. There looks to be some notches use for a grip, but again seeking some advice. Really trying to avoid a complete shower removal as this is on a second floor with no access to bottom. Possibly leaking around lip of strainer where it joins the enclosure, but even if so, not sure how to even make a good seal around that without actually removing it.
dbdezyne is offline
Old 10-11-2012, 07:02 PM   #10
johnjh2o
johnjh2o's Avatar
Likes Given: 620
Check the ring with the notches it should be tight. There is a gasket under the ring that seals the pipe to the strainer. Those notches are to tighten the ring onto the gasket.
John
johnjh2o is offline
Shower drain leaking dblhelix Showers and Tubs 27 06-06-2014 04:50 PM
Shower drain leaking to floor below (Photos) gymnast46 Showers and Tubs 10 07-11-2012 10:05 PM
Toilet overflow upstairs, water leaking through Light fixtures downstairs. zdenneh General Plumbing Help 12 07-15-2011 03:49 AM
Upstairs Bathtub Faucet Won't Run or Drain olsenjb General Plumbing Help 20 02-04-2011 01:14 PM
Newest Threads
