Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > DIY small Lawn sprinkler system
Thread Tools Display Modes
Old 04-24-2012, 04:41 AM   #1
kimbhoot
Default DIY small Lawn sprinkler system
Hello,
So I have this 27'x37' yard where I'm trying to add a sprinkler system. I've read several article and saw a post where this guy did a DIY sprinkler system for his yard. he used Flex PVC pipes for his system. after seeing that I got motivated to convert my existing system (garden hose and walmart stake type sprinklers) to a slightly better one where I don't need to stand and watch.
I bought some Orbit timer and just need to run some pipes in two spots and some heads. so here's what I'm thinking, run some standard PVC (since they're much cheaper than flex pvc) to two spots that I've determined and bury the pipes probably 6" in the ground with shovel or whatever tool I can use.
the parts that I haven't figured out yet is, how am I going to connect the water line to the pvc from my outside water tap. how do I prevent backflow and how do I drain the water out before winter.
please feel free to comment on my existing plan and help with this diy plan.
your comments are greatly appreciated.
Thanks.
kimbhoot is offline
Old 05-04-2012, 04:27 AM   #2
doctordirtpro
You typically want to run the pvc pipe into a manifold that is operated by your timer. I believe standard is 1 inch pvc.
If you wish to feed the pvc directly from a hose or outside water tap, I guess you could use a female faucet adapter with a PVC fitting with female thread on one end (connecting to your tap) and then goop the pvc pipe to the other, unthreaded end, as show here.
doctordirtpro is offline
Old 05-04-2012, 11:27 AM   #3
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
Here in CA we typically use 3/4" valves and 3/4" pipe for our sprinklers. Some use 1" but it is more rare and kinda overkill. A lot use 1/2" but if you have more then a couple heads or plan on it in the future you wont get the volume needed to run them right. I have six stations and they tap off of my mian line just before in enters my house.
Chris is offline
Old 06-10-2012, 04:07 PM   #4
CornerWrench
CornerWrench's Avatar
I cringe at the thought of an automatic irrigation system being run off a faucet. Rather see you tie in at the water line leading to the house and put in a ball valve and drain. Then use these for electric valves and back flow. http://www.irritrol.com/valves/valves_2700s.html
If you are running 1-5gpm then 1/2" will be okay. 5-9gpm use 3/4" 10-15 use 1"
Corner Wrench......Pipe Cutters......Threaded Rod Cutters.... and more.
CornerWrench is offline
Seeking advice on automating a lawn sprinkler system on a pump JRL2037 General Plumbing Help 4 06-10-2012 04:01 PM
What HP pump needed for 12,000 s.f. lawn sprinkler system? HoneyDo Pumps and Wells 3 04-26-2011 01:48 PM
What HP pump for 12,000 s.f. lawn sprinkler system HoneyDo General Plumbing Help 1 04-25-2011 03:53 PM
DIY sprinkler system Barber General Plumbing Help 20 03-23-2011 12:32 PM
Lawn Chairs Admin General Discussion 36 04-16-2010 09:29 PM
Newest Threads
