Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Has anyone used a LAKOS Twist II Clean Filter?
Thread Tools Display Modes
Old 04-23-2012, 10:36 PM   #1
Joelk
Default Has anyone used a LAKOS Twist II Clean Filter?
In trying to deal with my sediment problems I have come across Ads and YouTube Videos about this filter.
It seems like a quality filter and I like the fact that I should be able to just backflush it instead of changing filters all the time.
It has a mesh filter and the finest mesh they offer is rated at 105 microns. I wonder if this will be fine enough to remove a good portion of the very fine silt(no sand, probably clay) that rapidly clogs the element in my 10 x 4.5 "Whole House Filter".
I am trying to get things to the point where I would not have to replace the WHF Cartridge more that ever 2 months, hopefully longer.
Anyway, I would appreciate any feedback from anyone using the LAKOS Twist II Clean Filter.
Thanks, Joel
Joelk is offline
Old 04-24-2012, 06:38 PM   #2
speedygas
Hi Joelk - I have tried the LAKOS Twist II Clean Filter and it works as stated. 2 not have to replace the cartridge after every 2 months, I am not sure.
Its a great product though.
Speedygas your local plumber in London
speedygas is offline
Old 05-05-2012, 02:34 PM   #3
doctordirtpro
105 microns is pretty fine mesh, and this appears to be a pretty good product, based upon testimonials I have read from installers and homeowners who previously chose other options. I think it won some award for being one of the best new products of 2011 at the World Ag Expo in California a few months ago. They made a separate website to answer basic questions at twistiiclean.com.
doctordirtpro is offline
Old 05-05-2012, 03:13 PM   #4
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 198 Times on 181 Posts
Likes Given: 46
These things aren't new, Vu-Flow has been selling these since I was a kid. They plug up just like the rest of them. Backwashing sounds like a good idea, but the clay will more than likely stick to the screen and stay there.
http://vuflow.rusco.com/
speedbump is offline
Old 05-07-2012, 12:31 AM   #5
Joelk
I went to the Vu-Flow website and looked at the Vu-Flow screen type filters. I did not see any that backflush the way the Lakos Twist II Clean does. If there is a Vu-Flow(or any other brand) product that does an actual backflush the way a Lakos T2C does, can you please provide the model #?
From watching the videos of how they work, it seems to me that the Lakos T2C backflush process would clean the screen much more effectively than a "surface flush" type filter that basically just runs water over the surface of the mesh.
The Lakos T2C will mount very conveniently without having to reposition any of my other plumbing lines. I can just replace an existing 12" nipple with the Lakos T2C, some bell reducers(I plan to buy the 1.5" model as it has a lot more surface area) and some short nipples.
I will have the screen filter mounted in a location where I can very easily flush it as often as needed, once a week or once every two weeks would not be a significant imposition.
I ordered a Lakos T2C last week, but it is currently on back order and I could cancel the order if I come across a filter that I like better, before it is back in stock.
Joelk is offline
Old 05-07-2012, 12:50 PM   #6
speedbump
speedbump's Avatar
Likes Given: 46
Claude Laval invented the centrifugal sand filter back in the 70's or thereabouts. They worked very nicely on sand that was heavy enough to be easily settled out. The fine sand went right on through. I think he sold out many years ago, and the new owners are branching out. The big box stores make it real easy for companies that make these undersized filters to move lots of product.
If you really think that unit will help your water problem, get one. Let us know how it worked out for you.
Old 05-07-2012, 09:45 PM   #7
doctordirtpro
Default TwistIIClean info
I believe Claude Laval still owns the LAKOS company and all their products. And I believe the TwistIIClean filter works/cleans quite differently than the other filters that came before it from other companies (Vu-Flow and others). I think you need to depressurize the system to clean the filter on most of the others, among other differences.
Old 05-08-2012, 01:15 PM   #8
speedbump
speedbump's Avatar
Likes Given: 46
Your probably right, but I still have no use for a one faucet filter being used for a whole house.
Old 05-17-2012, 01:46 AM   #9
Joelk
My LAKOS, Model T2C-150-140 filter arrrived today and I installed it. It has 1.5" inlets and outlets and a 140 mesh(105 micron) screen.
It seems to be very well made and works exactly as advertized. Backflushing is super easy and although I did not run the water long enough to build up a lot of sediment on the screen, it seemed very effective at cleaning the screen when I did backflush it.
I have not run it long enough to know how long I can go between backflush/cleanings of the T2C, but it definately is catching a lot of the sediment before it is getting to my WHF so I know my WHF filter cartridgees will last MUCH longer than W/O the T2C screen filter.
I'll post again after I have been using it for a while to advise how frequently I have to backflush the T2C and how frequently I have to change the cartridge filter in my WHF.
Joelk is offline
Old 09-07-2012, 08:44 PM   #10
netcynergy
Established Member
I bought two of these filter setups - the 1.5" with 100 mesh screens the end of April'12,, Screen collapsed inside the filter letting sand into my water system.. LAKOS would not honor the warranty but I can wait 2 to 3 months to get new one in if I pay for it. Buyer Beware...
netcynergy is offline
Blockage near clean out tif0515 General Plumbing Help 5 12-23-2011 01:48 AM
Water heater leak with a twist CaliFred Water Heaters and Softeners 10 07-27-2011 01:24 AM
Sewer Clean Out Victor General Plumbing Help 6 06-15-2011 01:24 PM
Flapper repair with a twist DBLJ Toilets and Sinks 1 08-28-2010 12:44 AM
Comercial Clean outs? Montybell Plumbing Building Code 14 01-18-2010 06:59 PM
Newest Threads
