Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Grundfos Recirculation Pump Noise.
Thread Tools Display Modes
Old 02-18-2010, 12:01 AM   #1
Redparis
Default Grundfos Recirculation Pump Noise.
I have a Grundfos UP 15-18 B5/LC 1/25 HP recirculation pump at my residence and it started making a very loud, high pitched scream. I unplugged it, and the next day I plugged it back into the AC and the noise has now stopped.
What could have made this noise, and is the pump going bad? It has been in use for only 1.5 years.
Thanks
Redparis is offline
Old 02-18-2010, 02:09 AM   #2
Driller1
Driller1's Avatar
Liked 1 Times on 1 Posts
Thanks
Contact your dealer. That does not sound good. Do not wait for the warranty to go off.
Driller1 is offline
Old 04-13-2014, 03:32 AM   #3
chewy
I know this is 4 years old, but did you ever find a solution? I just moved into a new house and they had one installed in the back. It's making the same noise every so often. Wouldn't know who to call to get it replaced/fixed.
chewy is offline
Tags
Grundfos, recirculating pump, noise
Hot Water Recirculation Pump Recommendations 123champ Water Heaters and Softeners 36 10-11-2014 02:18 AM
Grundfos Pump install location right? charless917 General Plumbing Help 27 02-17-2012 05:28 PM
Hot Water Recirculation Pump Questions jborchel General Plumbing Help 4 02-04-2012 12:37 PM
Grundfos Comfort System Valves and PEX jamesnseattle Plumbing Products 4 07-15-2011 06:00 PM
Vibration and noise from water pump inlet wunof11 Pumps and Wells 5 05-16-2011 09:19 PM
Newest Threads
