Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > Baffled by backups
Thread Tools Display Modes
Old 02-14-2012, 03:15 AM   #1
Default Baffled by backups
Every so often my drain stops up on the way out to the city's lines. It's very hard to get a plumber out, so sometimes it'll be weeks before that can happen. So here's what I am having trouble with: The line has a tendency to clear itself. So if i get a plumber, the line runs clean as a whistle. Other times it will somewhat clear but I can see the drainage hitting a roadblock and backing up. Other times it will clear on its own and look as if I've had the plumber come out...smooth flow without slowing or stopping. WTH!!???
eldub is offline
Old 02-14-2012, 05:07 AM   #2
Liked 15 Times on 11 Posts
Likes Given: 20
Cracked drainage piping and a fluctuating water table ?????
you should have it camera'd
is there a consistancy to it at all ?? i.e. does it block after a given amount of flow from one or more fixtures? you could attempt to replicate it a few times and see, this would give better insight as to the nature of the problem. The homeowner often knows exactlly whats wrong but doesnt realize it, or have the means to solve it... thats what makes plumbing sometimes a detective type job.
LiQuId is offline
Old 02-14-2012, 04:47 PM   #3
Master Plumber
PrecisionPlumbing's Avatar
Seems like you need a repair. Use a sewer camera
‎(469)-248-2136 Precision Plumbing providing Service Repair Remodels Installing Quality Products With a Best Rate, Best Warranty Guarantee! Serving the Dallas,Texas DFW MetroPlex for Over 10 Years! Clean job sites, Quality work. Service You Can Trust! M-39887
PrecisionPlumbing is offline
Septic Tank - baffled jreist Septic Tanks 9 09-21-2011 08:29 PM
Newest Threads
