Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Frustrated with Bad Water Pressure
Thread Tools Display Modes
Old 01-26-2012, 08:40 PM   #1
blair
Default Frustrated with Bad Water Pressure
I've installed a new shower and am getting horrible pressure, I can use it to shower but it would take hours to fill up the tub (it was fine before this installation). The sink in the bathroom gets normal pressure. I've removed the showerhead and there isn't anything clogged (bad pressure even with the head removed). I've removed the faucet (diverter valve is attached to it) and I get bad pressure out of the faucet pipe. I've replaced the mixing cartridge in the shower handle and it doesn't have any affect. When I remove the cartridge and turn on the water to the house, I get a great spray out of the rough-in valve. I've even run bailing wire through the pipes up to the showerhead and down to the faucet to check for obstacles - none were found. I keep thinking it must be the cartridge but am running out of ideas.
Does anyone have any suggestions?
Thank you.
blair is offline
Old 01-27-2012, 12:53 AM   #2
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
Make of valve or picture of the cartridge?
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 01-27-2012, 01:38 AM   #3
blair
The cartridge is a Delta: http://www.deltafaucet.com/repairpar...s/rp46074.html
The rough-in valve is a hansgrohe:
http://www.plumbersurplus.com/Prod/H...119030/Cat/281
I bought them from Ferguson's which is supposed to be a good supplier up here in the DC metro area.
blair is offline
Old 01-27-2012, 08:04 AM   #4
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
is it possiblle that you are hitting the safety stop. i installed a few of these and they are all kinda odd, there is a stop and then a bypass, you press in on the mixer and turn more.
you should be using a matching cartridge for that valve hansgrohe should have on especific to that rough in body.
LiQuId is offline
Old 01-27-2012, 01:39 PM   #5
johnjh2o
johnjh2o's Avatar
Liked 722 Times on 546 Posts
Likes Given: 615
Liquid is correct if it's a Hansgrohe valve body you should be using there cartridge not Delta's. If you look at there valve body it is similar to Delta's but is not the same.
John
johnjh2o is offline
Old 01-27-2012, 05:01 PM   #6
blair
Thanks. I'll take a look tonight, the cartridge is what ferguson's told me matches. I was told Delta bought Hansgrohe?
blair is offline
Old 02-03-2012, 08:03 PM   #7
blair
Just received the new cartridge from Hansgrohe directly and they sent a Delta cartridge - which they are telling me is the correct pressure balance cartridge. Of course, it didn't work...
Any other suggestions out there? Am I to go back to stage one and reinstall a new rough-in valve and shower system?
blair is offline
Old 02-03-2012, 09:01 PM   #8
johnjh2o
johnjh2o's Avatar
Likes Given: 615
It's beginning to sound like you installed the valve body upside down. That would explain why you have better pressure to the shower head then you have to the tub spout. If you have access to the back of the valve body there is a arrow on it that should be pointing up.
John
johnjh2o is offline
Old 02-03-2012, 11:47 PM   #9
LiQuId
Likes Given: 20
^ thats a grerat idea... this could well be the problem. I had never really thought that one would be restricted, but have never installed one in the upside down position if for nothing more than the fact of the arrow and the "this side up"
LiQuId is offline
Old 02-04-2012, 12:07 AM   #10
johnjh2o
johnjh2o's Avatar
Likes Given: 615
Quote:
Me!! the only time I made a mistake was the day I thought I did. Just kidding.
I don't think I have but I have seen it done before. One other thing to remember about T&S valves never use PEX or CPVC on the tub spout. That will cause a restriction in that line that will force some water out the shower head when filling the tub.
John
johnjh2o is offline
T-ing Two Water Supply Lines for Greater Water Pressure JZeld General Plumbing Help 15 03-12-2012 08:13 AM
water pressure sky rockets when water heater is on jfrisby General Plumbing Help 2 02-16-2012 03:45 PM
Cold water pressure lower than hot water Va_guy General Plumbing Help 3 07-11-2011 12:50 AM
Water Pressure 110-120 PSI - My problem or the water co's? WillJohnston General Plumbing Help 11 03-18-2011 12:55 PM
Newest Threads
