Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Building Code > I hear my nieghbor flush
Thread Tools Display Modes
Old 11-06-2011, 10:57 PM   #1
Default I hear my nieghbor flush
I live in a side by side 2 story new home in NJ. Whenever my nieghbor flushes his toilet I hear the drainage noise through my tub next door. Our master bathroom share the same firewall, meaning that the homes are idenetial but opostie layouts.No pipes are shared between the homes firewall so how is this possible? I blleive the only places our sewagre may share is in the mian pipe that goes out to the street. Could it be pssoible that the noise is traveling that far back to my tub shower drain. It is all PVC
Billm9555 is offline
Old 11-08-2011, 01:51 AM   #2
Liked 966 Times on 776 Posts
Likes Given: 1739
Why are you certain that there is not shared piping through the firewall?
phishfood is offline
Old 11-28-2011, 07:42 PM   #3
Where exactly do you hear the flush? In the tub drain itself or in the wall near the tub?
LeakFinder is offline
Old 07-21-2013, 11:39 AM   #4
pvc sucks bro thats why they went cheap with pvc shuld have used cast
brandon90 is offline
Old 07-21-2013, 02:05 PM   #5
AQualityPlumber's Avatar
Liked 13 Times on 11 Posts
You are probably hearing an echo of the water inside the pipe. It is possible that they did not vent correctly. Your tub is always going to do this, unfortunately there really is no solution. Keep the drain plug closed when you're not using it. This may eliminate the sound. I find it hard to believe you are hearing it in the walls though. Duplexs should have at least a 2 hour fire rating and pvc is solid core. As far a plastics go pvc is the quietest.
A Quality Plumber Inc.
AQualityPlumber is offline
Toilet flush problems..........GRR! smitty81 Toilets and Sinks 6 04-29-2012 01:07 AM
help with flush valve dolfans Toilets and Sinks 3 02-17-2012 09:50 PM
Flange Not Flush Wth Floor vabear Toilets and Sinks 2 02-06-2012 08:34 PM
Dual Flush toilets Plumbing Products 4 06-30-2011 02:50 PM
Flush O Meter icelikeaninja General Plumbing Help 4 04-06-2011 02:27 AM
Newest Threads
