Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > jet pump and water tank
Thread Tools Display Modes
Old 11-05-2011, 10:09 PM   #1
dolfans
Default jet pump and water tank
Earlier in the yr i had to replace the jet pump and yrs ago i had to replace the water tank. When the pump was replaced (lowes hardware) it was quite when running. Now it is louder why? Can the water tank bag busted? Anything i can do to find out if it is busted? thanks
dolfans is offline
Old 11-07-2011, 12:29 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
If the bladder in the tank has failed the pump would be short cycling.
John
johnjh2o is offline
Old 11-07-2011, 02:48 PM   #3
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 211 Times on 192 Posts
Likes Given: 46
If you bought it at Lowes it's probably on it's way out. If your lucky, the motor will have ball bearings not bushings and they can be replaced. The bearings are about the only thing on a motor that can make noise. The only pumps that are noisy are the plastic ones and they are noisy out of the box.
If you bought the bladder tank at a big box store and it's over 1.5 years old, it's probably bad. If you want to learn more than you ever wanted to know about bladder tanks, go here.
speedbump is offline
Old 11-07-2011, 07:30 PM   #4
Driller1
Driller1's Avatar
Liked 1 Times on 1 Posts
The big box stores sell junk.
Same brand and model...not made the same.
I did not believe that....I thought if it looked the same and was the same brand and model it would be fine.
Then our salesman took me to Home Depot.
He had me pick a jet pump, a submersible and a tank.
Then we went back to my house and took them apart.
UNBELIVABLE!!!
Now, you can take from that what you will.
Buy from a dealer that sales to pros.
Speedbump is one of the better.
Driller1 is offline
Old 11-07-2011, 11:53 PM   #5
dolfans
The water tank was bought at a plumbing store and the jet pump was from lowes. The tank is maybe 7 yrs old if that. The pump less than a yr. The old pump went out and was running and hot. The plumber went to get the pump and got it at lowes,on the phone day before said lowes stuff was not good. About a week later had no water pressure(hardly) when using 2 water items(washing maching and sink etc). He (plumber) said the bladder maybe busted. He drained the tank when hooked up the pump and if remember right had some brown water come out. The pump was very quite for awhile and now can hear it come on. Thanks
dolfans is offline
Piston pump & pressure tank? beerman Pumps and Wells 17 04-07-2016 01:05 PM
Holding Tank Pump Clogs dennisl2k079200 Drain and Sewer Cleaning 1 02-17-2012 04:01 AM
Pump/pressure tank detective needed ngermain Pumps and Wells 1 05-05-2011 03:59 PM
Moving bladder tank and pump upstairs khickey General Plumbing Help 5 12-03-2010 02:08 PM
Hot water recirc pump installed, now hot water in cold lines? hevykevy420 General Plumbing Help 0 09-09-2010 03:35 PM
Newest Threads
