Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Tools and Equipment > Need more info on Ridgid Propress
Thread Tools Display Modes
Old 09-30-2011, 11:51 PM   #1
plumbps
Default Need more info on Ridgid Propress
Hi,
I'm new to the forum and do residential plumbing repair. I've heard about crimp tools and am currently looking at a Ridgid 100B Cordless Crimp tool on eBay. I'm an old school solder and torch guy. Could anyone give me pro's and con's on getting one of these tools? I'm also wondering if this is the right model or should I be looking at one of the higher end models. (300 series?)
This is the tool I'm looking at if it helps:
eBay - Ridgid Propress
plumbps is offline
Old 10-05-2011, 10:03 PM   #2
Fansplumbing
Master Plumber
We've been using one (in accessible locations only) for about three years and I've never had any problem. My only thought is, the only thing sealing the line is an O-ring, so I wonder what the life will be. (That's why I won't let my guys use them where the joints aren't easily accessible.)
Fansplumbing is offline
Old 10-06-2011, 12:01 AM   #3
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
I have used this system before and have also fixed leaks that happened due to the deterioration of the O ring, Im not convinced that its an awesome system.
Pros .
Quick, Can be done on a wet or dry pipe ( soldering a pipe must be dry and not letting by )
No Flame so No risk of fire ( though I have yet in 10 years to cause a fire by soldier )
Cons.
#1 COST of fittings. ( much more expensive than standard and not as easilly availablle )
#2 FAST, ( if the run is not thought out properly a inexperienced guy can quickly make a mess and have joints that are impossiblle to Crimp in their locations... see also #1 above, these fittings arnt cheap )
#3 Not as Tried and True as Soldiering
#4 Much heavyer than a torch to carry around, changing heads is a pain in the arse.
One experience that Pissed me off..
We had recieved one of the early models of these for our galvanized heating risers in a building and, being a commercial building ( condos ) we had not much room to rough in all of our pipes. We had several pipes in the given 2x6 wall, a domestic cold and hot riser, a Recirc, a vent stack, a supply heating riser, a return and another return ( system was a self balancing reverse return ) normally not a problem with sweat fittings but the heads for the Press fit gun ( press fit was for galvaized, Pro press was for the Copper ) needed a LOT of space for clearances between the pipes for sizes over 1 1/2 " if memory serves it required 3 1/2 clearance around the pipe to properly crimp it making it Extremely difficult to configure as we simply did not have the real estate. Also if the crimps wernt perfectlly alligned the machiene would crimp them at angles ( I HATE un-plumb Pipes ) I have also encountered a situation where the temporary power was not sufficiantlly powering the machiene and upon testing EVERy joint leaked making the "time saving" very costly ( personally I believe it was the heads being un maintained by the company that did that one though )
I should also note that it was in an area of great expansion and contraction that the o rings failed on the heating line... I have not seen a proper copper crimped line leak.... yet.
IMO.. Stick with soldier. this was maybe 6 years ago that I last used the Pro press system.
LiQuId is offline
Old 10-06-2011, 12:06 AM   #4
LiQuId
Likes Given: 20
upon looking at the add properly, this tool looks like a cadilac compared to the POS. I used.
I will point out to you the side clearance of the jaws though, this is somewhat more slender but keep in mind that you have to be able to open the jaws to get around the pipe to be crimped. and that for sizes 1" and less Soldering is quick and easy and that I would rather use pex for these sizes if speed is of the essence.
LiQuId is offline
Old 10-10-2011, 03:57 PM   #5
plumbercary
plumbercary's Avatar
I love propress, used it in CA all the time
plumbercary is offline
Cast iron info needed oakumboakum General Plumbing Help 1 09-06-2011 12:18 PM
Ridgid ask_eddie Plumbing Tools and Equipment 1 05-08-2011 12:52 PM
Info on sewer lining permoliner Drain and Sewer Cleaning 0 04-01-2011 06:50 PM
Info on those 'push to connect' systems bggas400 General Plumbing Help 7 12-05-2010 02:26 PM
Ridgid Seesnake? Blanks Plumbing Tools and Equipment 0 01-13-2010 03:52 PM
Newest Threads
