Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Gas water heater - to drain or not to drain - Advice needed
Thread Tools Display Modes
Old 09-29-2011, 11:39 PM   #1
djmikmik
Default Gas water heater - to drain or not to drain - Advice needed
Hi,
I have a gas water heater that was part of a new house that was built in 2003. It has never been drained before,
An employee from Lowes told me that since it is relatively old and was never drained before I should probably NOT try to drain it as it can create damage to the heater.
Any insight on his advice? appreciate your feedback!
Mickey
djmikmik is offline
Old 09-29-2011, 11:56 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 692 Times on 526 Posts
Likes Given: 579
The heater is at the age when most fail. (seven to ten years) I don't think I would drain it.
john
johnjh2o is offline
Old 09-30-2011, 11:30 AM   #3
burchis
I am curious to know why draining the tank would cause damage.
burchis is offline
Old 09-30-2011, 12:51 PM   #4
johnjh2o
johnjh2o's Avatar
Likes Given: 579
Do to the age of the tank and not ever being drained the sediment in the tank may be preventing the tank from leaking.
Most people are under the impression that you turn the water off then drain the tank. What should be done is connect a hose to the drain on the tank and without turning the water off open the drain and let it run until the water from the hose becomes clear. This uses the water pressure to flush the sediment from the tank. After that has been done then you drain the tank.
John
johnjh2o is offline
Old 10-04-2011, 02:00 PM   #5
AJay
Moron
Liked 3 Times on 3 Posts
John
We just had a new water heater installed a couple of months ago. There was so much sediment that they had to drain it from the top to remove it.
How often should a water heater be flushed? every six months? once a year?
AJay is offline
Old 10-04-2011, 02:29 PM   #6
johnjh2o
johnjh2o's Avatar
Likes Given: 579
Depending on water condition once or twice a year. You should be able to tell how bad it is by the amount of sediment that comes out when flushing. Try it every six months, if it's not to bad then go to once a year.
John
johnjh2o is offline
Old 10-05-2011, 05:03 PM   #7
KULTULZ
Jack of All Trades ~ Master of None
KULTULZ's Avatar
Liked 312 Times on 275 Posts
Likes Given: 172
Maybe also consider a sediment filter?
KULTULZ is offline
Old 10-05-2011, 08:42 PM   #8
sawsaw
the best thing to do is only buy water heaters with a self-cleaning, vortex system, which eliminates the need to drain to remove sediment.
sawsaw is offline
Old 10-05-2011, 09:01 PM   #9
johnjh2o
johnjh2o's Avatar
Likes Given: 579
From what I have seen all a self-cleaning heater is they have a dip tube that makes a turn at the bottom of the tank. The theory is to spin the water as it enters the tank. My question is where does the sediment go? I would think flushing it from the tank would be more effective. Just my opinion.
John
johnjh2o is offline
Old 10-08-2011, 03:20 AM   #10
djmikmik
John,
Thanks for replying to my original question.
So in this case should I connect a hose without turning the water off and perform the cleaning? or should I leave my gas heater intact?
John
djmikmik is offline
This floor drain looks awful. Advice? KansasJack General Plumbing Help 3 03-24-2012 11:16 PM
New construction washer drain improperly done help needed yzman720 General Plumbing Help 6 05-10-2011 01:45 AM
Thread type on drain of older water heater??? rodney_kranz Water Heaters and Softeners 2 04-04-2011 05:50 PM
Heat pump water heater drain lines sparky472 General Plumbing Help 9 03-22-2011 05:04 PM
water dripping into drain behind hot water heater mderren General Plumbing Help 8 10-22-2010 01:07 AM
Newest Threads
