Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Utility sink drain
Thread Tools Display Modes
Old 09-05-2011, 11:33 AM   #1
Rmdrent
Default Utility sink drain
Want to put utility sink in garage. What is the minimum distance above the main 3" drain line do I need. I don't know if I will have enough drop below the sink after the trap...
Thanks...
Rmdrent is offline
Old 09-05-2011, 12:07 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
If your asking what height of the floor the drain has to be, that depends on the sink your using. This is the most common one used and we rough the drain at 12" off the finish floor.
E. L. Mustee & Sons - 12 UTILATUB® Floor Mount Laundry/Utility Tubs ? Economy ? Extra Narrow
John
johnjh2o is offline
Old 09-06-2011, 07:51 PM   #3
Rmdrent
3" main is on other side of concrete wall about 12-18" below the floor of the garage ( where I want the sink). Need to know if I can tie in to the main with trap bottom about 12" above the 3" main... I haven't measured this exactly yet... Just want to find out what the min height I would need...
Rmdrent is offline
Old 09-07-2011, 02:16 PM   #4
Rmdrent
Quote:
Attatched picture of basement wall.
Rmdrent is offline
Old 09-07-2011, 02:25 PM   #5
johnjh2o
johnjh2o's Avatar
Likes Given: 620
Bring the drain through 12" above the garage floor. You do realize that you will also need a vent on the new line.
John
johnjh2o is offline
Old 09-07-2011, 05:52 PM   #6
Rmdrent
Yes, I will tie into an existing vent line on the first floor or run a new vent line out the side of the house...just not sure if I should tie the new drain into the vertical stack in the picture or bring it down and tie in horizontal extending that flush out?
Obviously I am not a plumber...but have had years of success trying.... so far...
just dont want to screw anything up on this one since it is my mother-in laws new home...
Rmdrent is offline
Old 09-07-2011, 08:34 PM   #7
johnjh2o
johnjh2o's Avatar
Likes Given: 620
Use a Y and 45 on the vertical line.
John
johnjh2o is offline
utility sink rudymxer Drain and Sewer Cleaning 4 11-23-2011 06:57 AM
New utility sink + washer drain line brownetowne Toilets and Sinks 0 06-26-2011 10:42 PM
How to add Utility Sink and Washer Drain to existing drain stack obriendigital General Plumbing Help 1 03-27-2011 02:15 AM
feedback needed on new plumbing to utility sink worldzfree General Plumbing Help 12 01-15-2011 12:07 AM
Oversized Laundry Tub/Utility Sink ndoll Plumbing Products 2 01-12-2011 04:44 AM
Newest Threads
