Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Leak under kitchen sink
Thread Tools Display Modes
Old 04-17-2011, 02:32 AM   #1
flyerphann
Default Leak under kitchen sink
Hi there,
thanks for any help you can give me on what is probably a stupid question.
Here's my problem. I came across a leak in my downstairs sink. It appears to be in the drain portion as it only leaks when water is running, and i can put my hand underneath, and those pipes get very wet, very quickly.
I watched an online video on fixing this (maybe smart, maybe dumb), and it had me unscrew a gasket near the top of the drain assembly. That unscrewed pretty easily, and there's a plastic piece I took out and cleaned. It was definitely dirty.
the video suggested cleaning it, as i did, and then using plumbers putty or silicone on the piece and re-inserting it. Here's the dumb question. They seemed to contradict whether to put the silicone on the top of the plastic, hwere it would meet the higher pipe, or on the bottom side (where it sits in the lower pipe).
I'm guessing it should be the top, but would prefer to be 100 percent sure on
that. It won't happen until tomorrow as i need to go buy the silicone and should probably just buy a new plastic piece as well.
Thanks for any help again, I do appreciate it!
flyerphann is offline
Old 04-17-2011, 01:26 PM   #2
phishfood
Liked 927 Times on 746 Posts
Likes Given: 1657
The most likely place for that particular washer to leak is on top, between the bottom of the strainer assembly and the washer. I personally use a good pipe joint compound on these type of fittings, and apply it to both the top and bottom of that washer.
phishfood is offline
Old 04-23-2011, 03:20 PM   #3
Mr_David
Easily Amused
Mr_David's Avatar
Liked 712 Times on 578 Posts
Likes Given: 488
^ And I thought I was easilly amused.
a.k.a. Krazedav
Mr_David is offline
Old 04-23-2011, 09:49 PM   #4
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
fill the entire sink with water up to the overflow and then pull the plug, NOW look underneith it should be easilly identifyablle where the leak is coming from.
Filling the whole sink makes more pressure in the pipes than just letting it run, which creates none.
LiQuId is offline
Old 05-05-2011, 10:24 PM   #5
flyerphann
Ok, so here's an update to things. I do appreciate the responses, even those that may have been poking fun at me a little bit for my lack of knowledge. I now have a new problem, which should be more entertaining,
especially if there's something small i'm overlooking (likely).
I took the drain apart, cleaned the washer, and I also re-puttied where the sink meets the strainer. I then went
to put things back together, and of course the 'gasket' that had unscrewed before now refuses to screw back
on. Well, I won't say refuses, because if i remove the plastic washer, i seem to be able to get it to screw on
sometimes...but once i put the washer back in place, even without putty on it, forget it, it never 'catches' and
comes right off.
So, once people stop laughing, any thoughts on what I could be doing wrong? I am screwing it on the right
direction, of course, i only know that for sure since i've tried both. Chances are *if* i get it back together,
somehow, the leak will still be there and I should just board up the room and never speak of it again.
Old 05-06-2011, 12:36 AM   #6
Mr_David
Easily Amused
Mr_David's Avatar
Likes Given: 488
Not poking fun at you but at tradesman11.
Not all drains are exactly the same. can you take a picture of it and post it.
Sometimes you just have to replace the parts with new ones.
A picture will help.
a.k.a. Krazedav
Mr_David is offline
Old 05-06-2011, 01:16 AM   #7
Caduceus
Caduceus's Avatar
Liked 348 Times on 254 Posts
Likes Given: 230
flyerphann, tradesman11 is an advertisement. Like a bot that gets into a forum so that you click on it o see their web page. Nobody was laughing at you and I can see how that form-like post could be perceived as a sarcastic jibe towards you. We will poke fun at each other at times, but after the problem is solved.
Do as Mr. David stated.
Caduceus is offline
Old 05-06-2011, 07:54 PM   #8
flyerphann
No worries, I'm certainly used to it if someone was laughing ;-)
I did just take a picture, and since I did that and used the flash, I noticed the threads on the pipe coming
down are pretty darn dirty/caked with old stuff. So i think first thing I should do is try cleaning those off.
Old 05-14-2011, 07:01 PM   #9
Another-Plumber
Another-Plumber's Avatar
Liked 6 Times on 5 Posts
Likes Given: 4
Flyer, just replace the basket strainer...
Another-Plumber is offline
Old 05-21-2011, 07:37 AM   #10
Dr-Copper
Dr-Copper's Avatar
Hmmm Sounds more like it is coming from the supply , not the drainage side.
Did I miss something here ????
Dr-Copper is offline
Is there a better way to tie in the Kitchen Sink? flannag General Plumbing Help 16 01-08-2012 01:21 AM
Delta Kitchen Faucet Leak scuba415 Toilets and Sinks 2 10-21-2011 12:39 AM
looking for help with kitchen sink heebie Drain and Sewer Cleaning 5 07-25-2011 01:22 PM
Kitchen sink drains extremely slowly and backs up (double sink) TimeForAction General Plumbing Help 6 10-22-2010 07:46 AM
Is my leak under sink or behind wall? SP284 General Plumbing Help 7 10-08-2010 11:19 PM
Newest Threads
