Clueless89
I've been testing my plumbing network from the pressure tank and switch out to the pump. Water pressure in house won't go above 20 psi and pump will not stop running. I adjusted the pressure switch to conserve the life of the pump. I have a franklin submersible pump between 200-300ft down.
When testing the pressure switch, I get 110-114v on each wire.
Pump is 230v, do I have a voltage issue here?
I tested the pump at the well casing and I get 120v each leg.
I tested the resistance at the pump with pump off and the multimeter doesn't change.
What should the resistance be for the pump from the well casing??
Thank you
Adam
Thank you
Adam
