Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Compression fitting
Thread Tools Display Modes
Old 01-20-2011, 05:10 PM   #1
barquito
Default Compression fitting
This may be a little outside the scope of this forum:
I need to fit a ferrule on the end of my aluminum air supply pipe for my air compressor. Assuming I find the right size (aluminium OD is a little bigger than copper), do I need to crimp the ferrule on the pipe, or does the nut just compress the ferrule like on water pipes?
barquito is offline
Old 01-20-2011, 09:00 PM   #2
NotAnotherRep
NotAnotherRep's Avatar
If its a soft Aluminium pipe like car break lines, then as long as the olive on the pipe slips on hand tight and not lose then by tighting the nut it will compress the olive into the joint. That's why it called a compression fitting.
NotAnotherRep is offline
Old 01-21-2011, 05:17 AM   #3
Mr_David
Easily Amused
Mr_David's Avatar
Liked 895 Times on 726 Posts
Likes Given: 593
Quote:
Originally Posted by NotAnotherRep View Post
If its a soft Aluminium pipe like car break lines.
Are you serious? They use aluminum tube for brake lines in the UK.
a.k.a. Krazedav
Mr_David is offline
Old 01-21-2011, 05:35 AM   #4
Mr_David
Easily Amused
Mr_David's Avatar
Likes Given: 593
Tubing comes in a large varity of sizes and types
Are you repairing like for like or are you modifing/changing something.
Some tubing is not always standard size. They are sized differenty so you have to use the right type of tube and fittings for the application.
a.k.a. Krazedav
Mr_David is offline
Old 01-21-2011, 06:12 PM   #5
barquito
Hey, that is better than sticking your feet throught the rusted-out floor board, like in the Flinstones!
I am probably just going to McGyver together whatever works, finish nailing my wood floor with this pile of crap compressor, then throw it off of a very tall buidling.
barquito is offline
Old 01-21-2011, 07:34 PM   #6
havasu
Administrator
havasu's Avatar
Liked 1130 Times on 922 Posts
Likes Given: 351
My 25 gallon Craftsman compressor has aluminum fittings from the pump to the gauges, but both ends have flared couplings, which can be rebuilt easily with a flaring tool.
havasu is offline
Using compression fittings in laundry room red General Plumbing Help 2 06-10-2012 11:56 PM
Compression cap? pawel General Plumbing Help 2 03-06-2012 02:01 AM
Copper/cpvc compression transition pita61 General Plumbing Help 6 10-27-2011 10:57 PM
Compression Adapter ctfoley General Plumbing Help 20 07-20-2011 05:04 AM
Compression joints ab56452001 General Plumbing Help 1 07-05-2010 01:48 PM
Newest Threads
