Im installing a bathroom for a friend and ive gotten to the point where the tile is down (around a protruding 3" drain pipe that was roughed in 20+ years ago) and all thats left to do is put the toilet in. I just cant seem to find the proper flange to use.
The problem is I cant use a flange that fits over top the pipe because there isnt enough of it under the tile surface to work with. I chipped away not even a half inch of concrete before the tile and thats where the pipe enters the 90 fitting. So my options are finding a flange that fits INSIDE the 3" pipe OR try and remove the pipe from its 90 fitting and insert the flange that i have which was the smallest diameter i could find (3" exactly, same diamater as the protruding pipe).
What do you guys suggest? The flange in the pictures below is what i was given at a plumbing store i visited today and specifically asked for a flange that would fit inside a 3" pipe, but it turns out its just a 3" insert itself. Do i go back and get a smaller one if it exists or should i attempt to remove the pipe and insert the 3" flange directly into the 90 fitting? It would be at a pretty good depth height for me if i did option 2.
Maybe there is another solution i cant think of? Thanks in advanced. Here are some pictures
