Hi gurus,
I have a water drainage issue off my driveway. Culprit seems to be the drain pipe in the middle, it easily gets plugged. I did the shop vac "suction" approach, sucked up a bunch of guck, some mud, even a few rocks. Now thinking to use a water jetter to try to punch through. Stuck spot is only ~15 ft in but I suspect it has to go 50 ft to get to the end.
Question: I have a Karcher electric pressure washer. Would like to add a 50' water jetter hose, something like:
http://www.amazon.com/dp/B00MV3DDIK/?tag=skimlinks_replacement-20
... but I think I need an adapter for the Karcher. Thus far haven't found much except for this specialized hose, which sadly is only 25':
http://www.amazon.com/dp/B003E59R84/?tag=skimlinks_replacement-20
Any advice/suggestions much appreciated. I have a large # of plumbing projects in my house so this will probably be the first of a couple posts .
Thanks
Thanks
