Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Tools and Equipment > Soldering copper pipe with heat gun? What about brass?
Thread Tools Display Modes
Old 03-10-2017, 03:31 PM   #11
frodo
Just call me Macgyver
frodo's Avatar
Liked 1844 Times on 1573 Posts
Likes Given: 381
yes, you can solder stainless steel and copper all you need is the correct flux
I have soldered SS to SS and copper to SS
Quote:
Originally Posted by Matt30 View Post
You can solder copper to brass without issues. You cannot solder stainless steel. If you are worried about open flame, get yourself a heat shield of some sort. Ditch the heat gun idea, trust me. Its going to be way harder.
yes,
My advice is free, If I have helped you and you wish to help the site out with a gift
use this link
http://www.plumbingforums.com/forum/...faq=supporting
frodo is offline
Old 03-10-2017, 04:28 PM   #12
plumb_bob_square_pants
plumb_bob_square_pants's Avatar
Liked 59 Times on 51 Posts
I was hoping you wod chime in on this one. Can you list the right Flux or where to get the stuff. I saved a pic you had posted one time. I'm just wondering it is the same stuff.
plumb_bob_square_pants is offline
Old 03-10-2017, 04:47 PM   #13
frodo
frodo's Avatar
Likes Given: 381
Quote:
sta clean liquid flux by harris
I get it at a welding supply house where i get my b tank refilled
https://www.amazon.com/Harris-SCLF4-...flux+by+harris
you just have to remember the 2 metals heat sync at different temps
get your flame off the ss and on the copper after you preheat.
and i have found that if you pre-tin your work, it works out a lot better
the stainless does not seem to ''wick'' the solder like copper
use this link
frodo is offline
Old 03-10-2017, 05:14 PM   #14
frodo
frodo's Avatar
Likes Given: 381
Quote:
Originally Posted by Nehmo View Post
Pre-Soldered Fittings use an alloy of solder that melts at a lower temperature than standard solder. ].
And there is the problem, we as licensed plumbers are required by code
solder or fluxes with a lead content which exceeds 2/10 [0.20] of 1 percent shall be prohibited in piping systems used to convey potable water
if it is a lower melting point then the lead percentage is going to be to high
Oatey Silver Lead Free and Safe-FloŽ Solder
melting point 415 degrees f - 455 f
tin 60-100 %
bismuth 1-5 %
copper 1-5 %
silver 1-5 %
Oatey 95-5 lead free
450 degrees f- 465 f
tin 60-100 %
antimony 3-7 %
in my opinion, all these neat tricks work great in a vice, in a closed environment
now, jump down in this ditch with the wind blowing
or maybe a sprinkle or 2
we work in the weather, very very very rarely do we ever get a chance to solder a pipe in pristine conditions as a lab setting
hell man, most of the buildings do not have windows yet !!!!!!!!!!!
use this link
frodo is offline
SHEPLMBR Likes This
Old 03-17-2017, 02:26 PM   #15
WyrTwister
Liked 4 Times on 3 Posts
How about in the crawl space under a house , where there is barely enough space to get my old , fat behind / gut ?
As an aside question , is tin / lead solder legal on things like automotive radiators ? Hot water heating systems ?
God bless
Wyr
WyrTwister is offline
Old 10-16-2017, 10:29 AM   #16
manju123
you can solder brass to copper no problem.stainless steel you cannot solder
manju123 is offline
Old 10-17-2017, 05:15 PM   #17
frodo
frodo's Avatar
Likes Given: 381
Quote:
oh contraire mon frčre
yes you can, been there done that
use this link
frodo is offline
Failing copper joins during soldering bawldiggle General Plumbing Help 29 03-19-2015 03:22 AM
Copper sweat soldering question JIMMIEM General Plumbing Help 3 10-16-2014 12:57 PM
How to clean copper pipe after soldering Fusion916 General Plumbing Help 6 08-07-2013 05:27 PM
Soldering copper pipe in tight location- Help Needed Pics included amodoko General Plumbing Help 26 08-16-2012 12:24 AM
pinhole leaks in copper pipes - soldering catpace Showers and Tubs 3 05-11-2010 05:11 PM
Newest Threads
