Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > What do I do about a floor drain in my basement before adding carpet?
Thread Tools Display Modes
Old 11-07-2011, 03:19 AM   #1
Default What do I do about a floor drain in my basement before adding carpet?
I am finishing my basement, which has 2 floor drains that connect to each other under the floor and then the main sewer system. One of the floor drains is in a portion I will not be finishing, near the washer, dryer, water heater. The other drain is in the middle of the floor where I will be putting a bedroom. I will be adding superseal dimpled polyethylene and then carpet. My basement has an everydry drainage system and sump pump with backup. What should I do about the floor drain?
angoved is offline
Old 11-28-2011, 04:00 PM   #2
Can help w/ plumbing ques
If you've lived there long enough to know for sure that water will not be an issue in the future, you can permanently cap and seal the drain. Otherwise, you might consider a tile floor leaving the drain functioning (be sure it has a working wet trap to keep odors under control) and use area rugs for barefoot comfort.
plumberhep is offline
Basement Floor drain filled with dirt Cambelious Drain and Sewer Cleaning 2 06-12-2012 03:07 PM
Adding a toilet to the basement. Existing drain comes through floor. TSGR General Plumbing Help 3 05-21-2012 04:01 AM
Basement Floor Drain Pump Up To Sewer?? toddbrew General Plumbing Help 1 04-29-2011 10:13 PM
Basement Floor Drain is slow GJinVA General Plumbing Help 3 12-31-2010 09:38 PM
Drain Cap in Basement floor leaks when it rains Javs General Plumbing Help 4 07-21-2010 12:21 PM
Newest Threads
