Where is the drain outlet for pool deck drains??
Mr_David
Easily Amused
Professional
Jan 11, 2010
4,170
1,061
Santee,Ca,
Had an issue with some pool deck drains. They've had problems for more than 2 yrs. I could not find the outlet. Logic seemed to say they must drain "That way" all the drains hold water. so I measured the depth of each drain and determined the drains flow 180 the other direction. I walked past the outlet several time. Then thought maybe they are up on this retaining wall behind this tree. :confused: :confused: Why is there a tree growing out of the side of a retaining wall :confused: :confused:
:eek: That's because it was growing out of the drain outlet. :cool:
Photo #1 There is a pool behind the brown fence and at the far end you can see the tree on the wall
