Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Snakes in my well video
Thread Tools Display Modes
Old 04-20-2017, 06:46 PM   #1
aqualset
Established Member
Liked 1 Times on 1 Posts
Default Snakes in my well video
I thought you would enjoy this video of me discovering snakes at the top of our well. Our well is now running constantly so I am thinking a snake dropped in possibly clogging something. Check valve seems out because when I turn off the breaker for the well, water pressure drops to zero and the pressure tank empties. Waiting on the plumber now...
Anyway, here is the video:
aqualset is offline
Zanne Likes This
Old 04-20-2017, 11:58 PM   #2
Matt30
Liked 706 Times on 535 Posts
Likes Given: 191
Ew! I have found snakes in septics, never a well though!
Matt30 is offline
Old 04-21-2017, 12:50 PM   #3
Valveman
Pump Controls Tech
Valveman's Avatar
Liked 66 Times on 55 Posts
Likes Given: 1
Snakes and mice are the most common things I pull out of pumps. They can get in through the smallest openings. Where there are mice there are snakes and vice versa. I would put a little chlorine down that well.
Wells that are left open are just dead fall traps for all kinds of critters. I once bailed out an old well that had been left open in a field and it had 20' or so of rabbits stacked on top of each other. Nasty job. Lots of bones, hide, eyeballs, etc., all chopped up and mixed together. It took a lot of work but we did get that well cleaned out and usable believe it or not.
Also one time I forgot to check the 4" pipes that had been laid on the ground by the well overnight. Must have been a half dozen rabbits got in that pipe overnight. After I got the 600' of pipe put back in the well I couldn't get it to show any flow on the flow meter. After taken off the flow meter there was a glob of rabbit parts that looked like it had been in a pressure cooker. Could tell they were rabbits but couldn't identify one rabbit from another. Needless to say after that I always dropped a rod down the pipes as I was picking them up off the ground with the pump hoist. Every once in a while we would flush a rabbit out of the pipe when it went vertical. The rabbit would land right at our feet and bounce off us and the truck a few times before getting his bearings and making a getaway. Always good for a laugh. And saved the rabbits life.
www.cyclestopvalves.com
Valveman is offline
Zanne Likes This
Old 04-21-2017, 01:52 PM   #4
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 200 Times on 182 Posts
Likes Given: 46
I second the chlorination of the well.
A little silicone in both ends of that PVC pipe would be a start to keep them out. Some of those Pitless caps have a turned down elbow with a screen on the end that over time will open up. The elbow is not necessary and should be replaced with a plug.
speedbump is offline
Zanne Likes This
Old 04-30-2017, 06:38 AM   #5
Zanne
Zanne's Avatar
Liked 181 Times on 161 Posts
Likes Given: 3245
Holy cow! How many snakes did you find? And what kind were they? They kind of looked like copperheads to me. Were they venomous?
Glad you got them out.
Zanne is offline
Advice on sewer video spoon Drain and Sewer Cleaning 2 02-04-2017 07:35 PM
how to post a video? Mr_David General Discussion 2 01-22-2015 09:19 PM
Open toilet seat's cover can prove to be open invition for snakes Cassandra Toilets and Sinks 6 11-04-2014 04:01 AM
Can Snakes Unclog Grease Clogs? JamesAA General Plumbing Help 4 08-07-2014 09:35 PM
question about video testing bamaflyfish General Plumbing Help 4 02-22-2010 02:04 PM
Newest Threads
