Hi all. I'm planning to replace an aging galvanized potable supply with a home-run PEX system. Our house has about a 20" crawlspace where all the piping is located. I have a few details that I'm having difficulty picturing how to do...
1. Lowest impact way of bringing new PEX up and out of the wall: I don't want to use copper stub outs because I don't have any experience soldering pipes, so I want to use some kind of bend support and bracket system. The only ones I've found are full-span stud brackets, but I'd like to make the smallest hole possible to minimize drywall repairs. I'm not necessarily concerned with shutoffs for the sinks because I'll have a manifold, but I will need to support a shutoff at the toilets. Any recommended solution?
2. Drill through floor joists for the routing, or just use clamps? (crawlspace)
3. Should I add a loop before going vertical to allow for thermal expansion?
4. From the manifold - where the piping groups leave the utility closet and enter the crawl space - can this be sealed with any kind of expanding foam sealant without reacting or degrading the poly?
Thanks for your input!
