D dangtran09 New Member Joined Nov 21, 2021 Messages 2 Reaction score 0 Location virginia, usa Nov 21, 2021 #1 does anyone know what this is? do i need to fix/repair/replace this asap? thanks
T Twowaxhack Currently in the Lab conducting research Professional Joined Feb 9, 2021 Messages 13,996 Reaction score 6,539 Location United states Nov 21, 2021 #2 Take the screw out and the handle off. This way you can match up the type handle you need. It’ll be square and tapered stem or have splines on the stem. Let’s find out.
D dangtran09 New Member Joined Nov 21, 2021 Messages 2 Reaction score 0 Location virginia, usa Nov 22, 2021 #3 are you saying i do need to replace this valve/handle asap? i still don't know what this 'white stuff' is on the handle. is it unsafe? what's the average cost to have someone replace this?
SHEPLMBR She-Plmbr River Rat Professional Sponsor Joined Mar 9, 2016 Messages 1,754 Reaction score 668 Location Augusta WV Nov 22, 2021 #4 You probably had a small leak and this is calcium build up caused from that. My suggestion is to replace it with a ball valve with a waste drain (the little cap at the bottom).
T Twowaxhack Currently in the Lab conducting research Professional Joined Feb 9, 2021 Messages 13,996 Reaction score 6,539 Location United states Nov 22, 2021 #5 dangtran09 said: are you saying i do need to replace this valve/handle asap? i still don't know what this 'white stuff' is on the handle. is it unsafe? what's the average cost to have someone replace this? Click to expand... i don’t know what the white stuff is either. If it’s not leaking just leave it alone until next time you need a plumber, then have the plumber check it.
