Which toilet flange type would help
gyoung
Apr 27, 2018
Help this toilet install is like old... its a miracle there is no existing flange almost as if the wax rings (or the excrement) held it.... My problem is determining how to clean that hole and then bolt the toilet
jeffmattero76
Nov 3, 2017
437
91
Pictures aren't working.
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
1,791
262
Boston, Massachusetts
can you access this from the basement??????if so and you have room cut out the closet bend(toilet pipe)close enough to the stack to get a 4 band coupling on it and repipe it
if its 2nd fl you should try drilling out the lead or breaking the flange out and doing it that way
fixitron
Feb 22, 2011
132
42
Warren, VT
There are products available that incorporate the flange with an extension and gasket or o-ring that will slip into the existing pipe. You then need to be able to screw that new flange to the existing floor, strong enough to bolt the toilet to so it won't move. Once that is installed, you will only need a single, regular wax ring. Note that the outlet of the toilet is only 2" in diameter, so inserting a new flange extension inside the existing pipe is not a big deal.
I would include an image of one, but Amazon, Home Depot, Lowes and Menards keep popping up first, and I do not want to encourage people to spend their money at those stores. Google "toilet flange repair" and choose "images" to get an idea of the choices, such as metal or PVC flange. Then go to your locally owned hardware store and ask them for one.
TomFOhio
Professional
Professional
Jan 20, 2018
1,092
228
Mansfield,, Ohio
Also, unless your in love with that toilet you might want to consider a up-date. When you put it back together
you may have to contend with that old gooseneck leaking. If your going to keep it get a new gasket before putting
back together.
johnjh2o
Professional
Lifetime Supporter
Jul 21, 2011
3,302
761
Melbourne, Florida
The biggest problem with that type toilet isn't the flush ell leaking but with the spud on the bowl leaking.
