When you don't want to go to the store for the right part
Discussion in 'General Plumbing Help' started by geoffhazel, Mar 16, 2019 at 12:16 AM.
  1. Mar 16, 2019 at 12:16 AM #1
    geoffhazel
    geoffhazel
    geoffhazel
    Active Member
    Jan 7, 2011
    35
    Seatle, WA
  2. Mar 16, 2019 at 1:38 PM #2
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,863
    2,157
    typically. happens every day
    here is a project for you to work on
    make a flange tail piece from a piece of 1 1/2'' chrome tubing pipe
    using only your pliers and a hammer
  3. Mar 16, 2019 at 1:56 PM #3
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    770
    174
    Mansfield,, Ohio
    Who soldered that pipe up??? Hopefully not a licensed plumber.
  4. Mar 16, 2019 at 2:01 PM #4
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,863
    2,157
    here is another, cap off a live copper water line
    Using 2 hammers. one as an anvil, the other to beat with
    close off/ smash flat, a copper water line that is LIVE
    then, cut the line, smash the end where you cut, and solder the line closed,
    not a permanent cap off. for emergency situations
  5. Mar 16, 2019 at 2:02 PM #5
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,863
    2,157
    we do that all the time for temp caps
    stub outs on water lines in a house under construction.
    never never for a permanent cap. but totally acceptable for construction
  6. Mar 16, 2019 at 2:07 PM #6
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    770
    174
    Mansfield,, Ohio
    For the cost of a cap we used to make them a little longer that normal and then when we cut them off we could use
    them for the next job.
    frodo likes this.
  7. Mar 16, 2019 at 3:06 PM #7
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,863
    2,157
    yep...
    you figure 8-10 1/2'' caps plus 2 -3/4 per house at $10.00 for all
    if you do 30 houses per year. that is saving $300.00
    real money in a tight competitive market
  8. Mar 16, 2019 at 4:36 PM #8
    FishScreener
    FishScreener
    FishScreener
    Aug 23, 2018
    202
    63
    83467
    My favorite found solution, was a fifty caliber lead bullet, pushed into a half inch copper, with the copper crimped into the grease grooves on the bullet with a tubing cutter.
    frodo likes this.
  9. Mar 16, 2019 at 5:31 PM #9
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,863
    2,157
    never thought of that...but can do
    83516_74bd303320fc7a55bff96d2142ebd66d_thumb.jpg 83512_8db1ad53fcce3048f7b9e56fcbe0e704.JPG
  10. Mar 17, 2019 at 3:30 PM #10
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,195
    1,268
    Southern California,
    Man, I want to shoot a 50 Cal again.
  11. Mar 17, 2019 at 6:16 PM #11
    WyrTwister
    WyrTwister
    WyrTwister
    Dec 6, 2015
    113
    10
    How many have used the bread trick when a valve does not quite shut off ?
    Wyr
    God bledd
  12. Mar 17, 2019 at 9:40 PM #12
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,863
    2,157
    guilty.. more than once
    how many of you guys have cut plastic with a string?
    here is a nifty little jig , easy to make, changes the direction of the cut from vertical to horizontal
    works real well in a tub box
Share This Page
