What's With All the Single Function Shower and Tub Faucets?
StrongEagle
Active Member
Dec 29, 2013
30
Houston, Texas
So... I visit Home Despot, then Lowe's then go online to a couple of outfits. They all sell single function, temperature control faucet valves in all of their sets. What's with this?
For example, I look at a couple of Moen's. They are all sold with the "Posi-Temp" valve, which means it will only control the temperature. But Moen also sells their Moentrol valve which controls both temperature and flow rate... just like all the old single handle shower faucets used to do.
Same thing with Delta... everything in the big box stores and most of the stuff on the websites controls temperature only... no volume control. And yet, like Moen, Delta sells both... single function temperature control and dual function temperature and flow control. As a matter of fact, Delta sells "Multi Choice Universal Valves" where the valve body is the same but the insert gives you one or two function control. Interchangeable Shower Valve with MultiChoice® Technology | Delta Faucet
So... I don't get it... why all of a sudden is my home shower supposed to be like far too many hotel room showers... on/off, temp control but no water flow control?
TIA
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,000
298
Boston, Massachusetts
TIA
I think the reasoning behind no flow control is the shower head by code is only allowed to put out 2.5 gpm
fixitron
Feb 22, 2011
161
52
Warren, VT
It is because plumbing codes were changed to prevent scalding from water that is too hot. That cannot be done with a two (or three) handled shower valve.
StrongEagle
Active Member
Dec 29, 2013
30
Houston, Texas
Thank you! I hadn't thought about that... limited flow means who cares about volume control when the volume is already so low... you turn it on high every time.
StrongEagle
Active Member
Dec 29, 2013
30
Houston, Texas
Actually, it can be done with a volume control knob, and all the biggies in the faucet manufacturing business still sell volume control valves... it's just that the kits with valve and trim hardware you find at the big box stores only have the temp control valve in them. You've got to "roll your own" to get something different.
Jeff Handy
Jul 5, 2019
2,029
381
Chicago suburbs
Many people want all the volume they can get.
Even having to dig out flow restrictors in the shower head, to get a decent stream of water.
And the trend is towards bigger showerheads which need lots of high flow volume, or even multiple heads that are often starved for enough water.
So nowadays, more volume is usually more better, haha.
StrongEagle
Active Member
Dec 29, 2013
30
Houston, Texas
Exactly! Considering a rain shower head, and I always do remove flow restrictors. But, that's also because I tend to turn the water flow off/down, while soaping up.
Ah well... looks like a custom ordering job.
Jeff Handy
Jul 5, 2019
2,029
381
Chicago suburbs
You can just add a volume control right at the shower head.
They go between the shower arm and shower head, and their main function is to stop water flow while soaping up, as you do.
The flow is usually still a trickle, not fully off.
Some have a twist lever, some have a push in, push back out type of control.
StrongEagle
Active Member
Dec 29, 2013
30
Houston, Texas
I'm thinking about going with a Delta valve system that has two handles on the shaft... one for temp, one for flow rate.
One of their options in their "multi choice universal valve" line - Interchangeable Shower Valve with MultiChoice® Technology | Delta Faucet
FishScreener
Aug 23, 2018
332
93
83467
The plumbing codes require that all the shower and tub faucets be temperature compensating to avoid the potential for scalds. So, you can‘t have a simple two handle faucet assembly.
StrongEagle
Active Member
Dec 29, 2013
30
Houston, Texas
Did you look at the Delta webpage? Or the Moen webpage ( Moen 101 )? All of the valves they sell are "anti-scald", that is, pressure balancing, to deal with sudden changes in pressure, regardless of whether they are single function or dual function. As a matter of fact, my old American Standard fixtures, installed in 1999, that I am getting ready to replace, are also pressure balancing.
So... I think that Geofd's comments about limited flow showerheads, are probably the most reasonable explanation for lack of choices at the big box stores.
And ya know... about the only reason I want to replace these is that I cannot find the trim hardware (escutcheon plate, dial plate, handle, etc)
StrongEagle
Active Member
Dec 29, 2013
30
Houston, Texas
I put a Moen shower and bath valve into a client's house. Works just fine except he wanted it a tad hotter. I searched high and low, could not get the valve to let any more hot water out. Sort of a pisser.
Was this the PosiTemp valve or the Moentrol? I'm kind leaning towards the Delta Monitor 17 series. They make a "high flow" shower only valve, but still trying to find flow rate specs for it. I like the idea of 2 handles on a single shaft...
Jeff Handy
Jul 5, 2019
2,029
381
Chicago suburbs
Be aware, many valves come in more supply pipe sizes than just 1/2 inch.
High flow often need 3/4 supply.
Some of the multi head shower rooms might need one inch, I don’t know.
StrongEagle
Active Member
Dec 29, 2013
30
Houston, Texas
Man, I'm getting a real education. Will call Delta in the morning about valve and cartridge flow rates.
Reminds me of the guy who walked into home depot paint department one morning. Four of us standing around. The guy says, "Give me a can of tan and a can of white." Little did he know.
