What's going on with my toilet
Discussion in 'General Plumbing Help' started by Wendland, Dec 8, 2019.
  1. Dec 8, 2019 #1
    Wendland
    Wendland
    Wendland
    Dec 8, 2019
    Cramerton, NC USA
    Hi folks. Have done a little plumbing but not sure what happening here. Moved into new place and guest bathroom toilet was silently spilling into the overflow. I adjusted the refill mechanism so it would stop refilling about 2 inches below the overflow. A few days later I checked and it was overflowing again. When I flush it only refills to the 2 inches below the overflow but after a few hours its overflowing again. I dont hear any water refilling or anything so not sure what's going on. Do I just need to replace the refill mechanism
  2. Dec 8, 2019 #2
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,197
    370
    North Reading, Mass.
    Yes! The fill valve is likely leaking water into the tank.
    They're are relatively cheap and easy to replace. But don't adjust it to 2" below the overflow. Instructions will likely suggest a 1/2" or so.
  3. Dec 8, 2019 #3
    Wendland
    Wendland
    Wendland
    Dec 8, 2019
    Cramerton, NC USA
    Thanks Diehard! I've replaced them before at my old house but wasn't sure if it was the same root cause. Thanks again for confirming
  4. Dec 8, 2019 #4
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    985
    211
    Mansfield,, Ohio
    Use a fluidmaster ball cock. They are easy to install and you can replace the gasket easily if needed.
  5. Dec 16, 2019 #5
    Riickk
    Riickk
    Riickk
    Active Member
    Nov 14, 2019
    41
    7
    Delaware
  6. Dec 16, 2019 #6
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    985
    211
    Mansfield,, Ohio
    If he doesn't already have a fluidmaster in the tank then some of these cheap fill valves are not that easy
    to repair. Cheaper to replace. That's what I do and then no call backs that way.
    GReynolds929 likes this.
Draft saved Draft deleted
Share This Page
