What valve for tub/shower install
Discussion in 'Showers and Tubs' started by Terry61, Oct 18, 2019.
  1. Oct 18, 2019 #1
    Terry61
    Terry61
    Terry61
    Oct 18, 2019
    South Carolina
    Need a tub/shower valve/trim to replace an old 3 handle faucet. Problem is the wall is 2 1/4" thick (metal lathe/concrete/tile) and a standard faucet I purchased would not work on the thick wall. Anybody got any ideas as to what valve/trim will work? If I have to I will upgrade to a single valve. I would prefer a valve with flow control if possible. Please talk to me like a five year old. I'm the handy type just not a plumber.
    I emailed Moen and the rep told me the Moentrol would not work and the Posi Temp would, but it didn't make sense because both have extension kits (which is what I thought would let them work) but the rep said the extensions didn't make the valve able to go in a thicker wall, so yep I am confused...
  2. Oct 29, 2019 #2
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    979
    211
    Mansfield,, Ohio
    Get the posi temp faucet and see if it will work. If not you can take it back.
  3. Oct 31, 2019 #3
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    not a Junior Member anymore! Sponsor
    Mar 9, 2016
    823
    164
    NOKESVILLE, VA
    Yes they do make extension kits for both. If you want flow control get the Moentrol. Otherwise go poistemp. And don't forget your extension kit.
  4. Oct 31, 2019 #4
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    979
    211
    Mansfield,, Ohio
    Wonder why Moen told them that the Moentrol would not work and the Posi-temp would.
Draft saved Draft deleted
Share This Page
