What type of pipe is this?
Discussion in 'General Plumbing Help' started by ED W., Dec 15, 2019.
  1. Dec 15, 2019 #1
    ED W.
    ED W.
    ED W.
    Dec 14, 2019
    6
    Maine
    DSCN1181.JPG Hello! Probably an odd question, but I'm coming into the middle of a project someone else started that I have to finish....We bought a new place recently and I'm finishing a boiler installation that the previous owner (or somebody, long story) started. Its a wood fired boiler, located in the garage and piped into the house. They had the pipe already laid and buried in the ground, I need to attach it to copper on both ends and a few other things. BUT... I thought it was PEX pipe (admittedly I'm not very familiar with PEX, still old-school with copper myself) It appears not to be. There are no markings on it whatsoever, which is perplexing to say the least. Measures 1" ID, and a 1" pex clamp-collar type fitting swims inside it. A brass barbed fitting like you'd use for Poly fits ok in one line, but loose enough to cause trouble in the other. A pair of standard screw-type hose clamps wont even begin to compress it. Any ideas what this pipe is and what type of fittings I need to connect to copper? I should add that 1 1/4" barbed fitting is way too big...
  2. Dec 15, 2019 #2
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,354
    403
    North Reading, Mass.
    Don't know for sure.
    Are you sure the markings are not embossed and hard to see?
  3. Dec 15, 2019 #3
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,268
    215
    Chicago suburbs
  4. Dec 15, 2019 #4
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,268
    215
    Chicago suburbs
  5. Dec 15, 2019 #5
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,268
    215
    Chicago suburbs
  6. Dec 15, 2019 #6
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,268
    215
    Chicago suburbs
  7. Dec 15, 2019 #7
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,354
    403
    A side note for the OP(ED W.).
    The size that's typically used to describe a pipe size is actually what is referred to as their "nominal" size.
    For example nothing on a 1" pipe actually measures 1".
    Dimensions of PEX SDR 9 (CTS) tube according ASTM F876 Standard Specification for Crosslinked Polyethylene (PEX) Tubing:
    Nominal pipe size: 1 1/4"
    Outside diameter: 1.375"
    Inside diameter: 1.069"
    EDIT: BTW...The O.D. of PEX was made to match that of copper, allowing you to use a variety of transitions fittings.
    When the tubing or pipe has the option to change the wall thickness(schedule or type), the changes are made to the I.D. and not the O.D.
  8. Dec 15, 2019 #8
    ED W.
    ED W.
    ED W.
    Dec 14, 2019
    6
    Maine
    Hey! Thank you all! I checked both ends of both pipes over again, there may have been some writing on one spot, but its so worn away that it just looks like a really poor and faded barcode now. I'm assuming maybe from being pulled through the shielding pipes in the ground. I'm going to check the links that J Handy posted above..... This would be a WHOLE lot easier if could walk into a store and buy fittings and see what fits instead of special ordering things I'm guessing about. But anything over 3/4" most places seem scared to death of carrying, and FORGET 1 1/4"!
  9. Dec 16, 2019 #9
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    271
    47
    Northwest Washington
  10. Jan 9, 2020 #10
    ED W.
    ED W.
    ED W.
    Dec 14, 2019
    6
    Maine
    You aren't kidding, they do have a lot of good stuff! I also had to deal with customer support (adding an item onto an order) and they were absolutely great. Search engine is a little wonky though, lol!
Draft saved Draft deleted
Share This Page
Group Builder
