Warrior9
I have a 3/4” Shutoff on my pex line. I want to relocate it further upstream (closer to my PRV) so I can finish my basement and have them both behind one access panel, instead of two that would be required now.
I also want to add another valve (on a different section of pex) to a new sillcock outside that would need a 3/4” valve with a drain.
I only have a 3/4” Viega PureFlow Press tool, so I’m looking for something compatible with this. I’m having a hard time finding valves with the sleeves already on them or ones that say they are compatible with the Viega sleeves.
In the photo, the bottom fitting looks like a Viega, but I don’t know what the upper one is.
Any advice for what I need to search for to get a valve that works with the PureFlow press? I would’ve thought this was more common, but I seem to be striking out on what I need to do. I looked up the model for the RWV shown in the pic, and it doesn’t look like anything special...just the normal pex barbed ends...but any pex ball valve I find says it needs crimped.
Thanks!
Thanks!
