Scott p
I have a well and due to the gpm it produces, the previous owner put in a 5000 gallon holding tank. The tank ran dry on 4/11 after leaving a hose on all night and the tank has not recovered since. The pressure tank is good, replaced the pressure switch as well. When I raise and lower the top float, it kicks on and fills the holding tank for about two minutes before shutting off. The tank now won’t recover above the bottom float. Thoughts on what’s wrong or how to correct? It’s not tripping breakers
